Question about Motorola Mobility SLVR L7 Cellular Phone
How to create safe folder
How to create a safe folder with password protection in my Motorola L7i.
How to save msg to memory card.
Posted on Feb 03, 2008
6ya staff
SOURCE:
Tip
How to Make Invisible Password Protected Folder Submitted by Srikanth on...
How to Make Invisible Password Protected Folder2761870.jpg Submitted by Srikanth on Thursday, 10 December 200930 Comments Do you want to password protect your folder? Do you want to make it invisible so that it remains unnoticed by the normal users? Well here is a way to do that. In this post I will show you how to make a password protected folder in Windows without using any additional software. Here is is step by step procedure to create a password protected folder.
How to create a Password Protected Folder
Step-1: Create a new folder (Right-click -> New -> Folder) and give it any name of your choice. For instance I name it as ABC.
Step-2: Now in this folder place all the important files, documents or any folders that you want to password protect.
Step-3: Now Right-click on this folder (ABC) and select the option Send To -> Compressed (zipped) Folder.
Step-4: Now a new compressed zipped folder gets created next this folder (ABC) with the same name.
Step-5: Double-click on this compressed zipped folder and you should see your original folder (ABC) here.
Step-6: Now goto the File menu and select the option Add a password.
ie: File -> Add a password
Now a small window will pop up and here you can set your desired password. Once the password is set, the folder will ask for the password every time it is opened. Thus you have now created the password protected folder.
How to make it Invisible
Step-1: Now Right-click on this password protected folder and select Properties.
Step-2: At the bottom select the option Hidden and press OK. Now your folder gets invisible (hidden).
Step-3: In order to unhide this folder go to My Computer – >Tools -> Folder options. Switch to View tab, scroll down and under Hidden files and folders you’ll see the following two options
  • Do not show hidden files and folders
  • Show hidden files and folders
Now select the second option and press OK. Now the invisible folder becomes visible in it’s location. To access it you need the password. To make it invisible again repeat step -1 through step-3 and select the first option and click OK. Now the folder becomes invisible once again.
I hope you like this post. Pass your comments!! Cheers
on Mar 30, 2010 | Computers & Internet
Tip
How to effectively use FileVault to protect your Mac (for Mac OS X versions 10.4...
FileVault.
Its name gives you the impression of something involving security for your Mac. But what exactly is FileVault in the Mac OS X system and how can it benefit you as a Mac User with one or more Macs?
The answer, really depends on you, in regards to just how secure you want to make your Mac computer or Mac portable notebook.
Apple Inc., defines FileVault, as a file protection system, as a built-in feature, which can prevent others from seeing or copying your files by using encrypted files in your Home Folder.
**ENCRYPTION STANDARD FOR FILE VAULT**
FileVault creates a separate volume for your home folder and encrypts the contents of it using the latest government-approved encryption standard, the Advanced Encryption Standard with 128-bit keys (AES-128).
Now before you start going into brain scramble trying to understand this encryption standard, I will simplify the term, defining AES-128, as "a very secure cryptic (hidden meaning) system of code", designed to make your files inaccessible, through a very strong password structure.
**SPARSE DISK IMAGE**
When created, in Mac OS X 10.3 Panther and Mac OS X 10.4 Tiger, what FileVault does is create a "Sparse Disk Image" or in plain terms, it is a single image file which holds all of the files and folders and content of a Home Folder (in regards to FileVault) in single disk image.
The primary purpose of the Sparse Disk Image made by FileVault, is to place all Home Folder content in one encrypted image, plain and simple.
** BASIC SETUP FOR FILE VAULT**
Setting up FileVault is not that difficult to setup.
All you have to do is click on the Apple menu icon located in the upper left corner of your screen and select System Preferences
* You will now be taken to the System Preferences window
* Click on Security.
The Security window will now appear, with three tabs:
General, FileVault and Firewall.
Click on the FileVault tab.
Now you will see the FileVault window.
This is the main window you will need to access in order to setup FileVault to encrypt your Home Folder and all its contents.
** Screen shot of FileVault for:
Mac OS X 10.3 Panther /10.4 Tiger
Mac OS X 10.5 Leopard /10.6 Snow Leopard
Make very sure you are reading the instructions which Apple has provided for FileVault, because you are now about to encrypt your Home Folder which, contains all of your files, folders and applications. In other words, your entire User account and its contents.
So before you even proceed to turn on FileVault, make sure you first create a Master Password.
This is is a very important step you should complete first, in the event you forget the password for your FileVault account you are about to setup on your Mac.
This way, in the event you forget your FileVault password, the Master Password is like your root password, there no more a low level account password, like the Master Password in regards to your FileVault account.
As a result, this is why I stress the importance of creating a Master Password.
Once you have created your Master Password, proceed to turn on FileVault and follow the onscreen prompts to encrypt your Home folder.
This FileVault encryption process can take awhile, so try to perform this procedure when you do not have any need to work on your Mac, or can leave it unattended for a few hours or more.
Once it is done your entire Home Folder will be encrypted.
(Remember, store that FileVault password somewhere safe!)
** FINAL WORD ABOUT THE MASTER PASSWORD**
Keep in mind, you are not required to setup a Master Password, in order to use FileVault, but let's face the facts here. WE ALL have forgotten a password or two (or 3, 4, or 20!) at some time in our overall computing/web surfing experiences. I know I have.
The last thing you want to do, is encrypt all your important files and folders and then forget the password for the FileVault account you setup AND the Master Password as well
So what am I saying about the Master Password?
***ITS IMPORTANT!!***
Hence, if you do decide to create a Master Password, please make sure to write it down, type it, stencil it, put it on 3x5 card and throw it in your home safe or the safe deposit box at your bank (or anything else you can think of), to protect this Master Password for future use as needed.
To forget this important password on top of forgetting the password to your FileVault (will use "FV" for sake of space, for most of the remainder of this tip) account is just plain not good.
The most common issue Mac users have is not the usability of FileVault.. It's forgetting the FV password.
A final word from Apple Inc. about this, to drive my point home:
"If the computer’s administrator doesn’t know the master password, and the user of the FV-protected account has forgotten the login password, the home folder and it’s contents are lost."
Since FileVault provides encryption, none of the password reset options work provided by Apple work. Your password IS your Encryption Key, so without it, your access to your Home Folder is gone. You will need to perform an Erase and Install from your system disk.
So if you are the Mac computer administrator and the user, you can see how this can turn out with a forgotten Master Password for FileVault
**FIRMWARE PROTECTION FOR YOUR MAC **
One other security feature in Mac OS X that I would be remiss not to provide some details about its use, is Firmware Protection.
Firmware Protection, is a low level protection designed to prevent other users from using the Single User Mode, with various scripting tricks using the UNIX based command line, in order to gain unauthorized access to your computer.
Open Firmware Protection is password protection option by Apple, (and not enabled) for the firmware of your Mac. When enabled, it will require a password from you before you can even reach the Desktop. Even more security in lieu of FileVault. But be forewarned, Apple does not recommend you activate this feature.
Another warning here as well: If you have forgotten the password for this protection as well, then there is no way to get around this but for one exception. Review the link I have provided below.
Review it, study it and know what you can with Firmware Protection, so you can know how to properly reset it as well as set it.
Here is that link for you regarding Setting up firmware protection for
your Mac and more: Setting up Firmware Protection in Mac OS X
I hope this Mac OS X tip from FixYa support has helped educate you on how to better, secure your Macs, sensibly and safely.
Stay tuned for more helpful tips and tricks from the Mactechtrainer!
Thanks!
Regards,
-Mactechtrainer
**HELPFUL LINKS***
From Apple Regarding FileVault:
For Mac OS X 10.4:
About Mac OS X 10.4 Passwords
Resetting FileVault Password for Encrypted Home Folder
*For Mac OS X 10.5 Leopard:
For Mac OS X 10.6 Snow Leopard:
About Mac OS X 10.6 Passwords
Mac OS X 10.6 - About FileVault
How to: Encrypting your Home Folder with FileVault
Mac OS X 10.6: Reset the password for a FileVault-encrypted home folder
Bonus Link :
Repairing a FileVault Protected Home Folder
on Feb 26, 2010 | Computers & Internet
Hi im anthony and i had bought a laptop from a guy and it has k9 web protection on it and im tryn to get it took off can u pleasde help me
there are two methods you can try.
Method 1
If you have the administrator account password for the local computer and the best way to uninstall K9 web filter from the local computer is to re-install it! Re-install k9 web protection will simply get you a new license code and a new password you can enter without the need of old password.
1.Open K9 web protection website 2.Click "get K9 NOW" tab on the top-left 3.Fill out the information and your email. 4.Download the K9 Web protection software from the link included in the email and keep a copy of the license. 5.Grab a version of the K9 web protection installed on your computer, a Google search should do the job. 6.Open "Task Manager" by press (Ctrl+Alt+Delete) and end the process K9filter found in the "Process" tab. 7.Now, you can safely delete the K9 web protection program files. Open computer explorer and go to the folder where K9 is originally installed. It can be found mostly at C:\Program Files/Blue Coat k9 Web Protection. 8.Remove the contents of the folder but not the folder. 9.Run the K9 web protection setup/installer file which has the same version as the one you just delete 10.Provide the license and create your new password 11.Point the installation folder to the same folder you just empty the contents earlier on 12.Now you can have a re-installed K9 web protection with a password you know. How do you uninstall K9 web protection now? Use the new password you just created If something goes wrong, install the K9 web protection program downloaded from Step 4.
Method 2
Reboot Windows into safe mode: restart your computer and hold "F8? key until you see the menu to choose "Safe Mode" Login to windows and go to "Program Files" directory and delete the K9 folder manually (delete only the contents but leave the folder) Click "Start"->"Run" and type "msconfig" Check the tab "Services" and tab "Startup" Un-check anything that is related to k9 If somehow this method is messed up, try to download K9 again to at least restore your previous installation. If this still does not work, try to install Revo Uninstaller.
Here is a video tutorial
Aug 24, 2011 | Dell Inspiron 1501 Notebook
How can sutep aofftwer fore motorola l7i
Go to the following website:
http://motoroladownloads.webs.com
Sign in with the following information:
Email address: [email protected]
Password: phone (spelled with a small p)
You can then download the Motorola Phone Tools (PC Suite) for your PC for free. Make sure you download the USB Drivers, too.
Mar 29, 2010 | Motorola Mobility L7I Cellular Phone
How to download games on my motorola l7i
download .jar format game form internet & then paste it in "kjava" folder of memory card. disconnect phone from PC & go to "games & application" ,select "memory card" & then "install new"
Mar 04, 2009 | Motorola Mobility L7I Cellular Phone
How to find my motorola L7i password
To know your password you will have to download a software P2K Advance Editor and p2k drivers those are the drivers by which your phone can be used in p2k mode. you can search for them in google.Connect your phone to the usb port then Run p2kAE (Advance editor) click connect in "p2k mode" you will see that a new hardware is found DON'T select install automatically select "install from a specific list or folder". tick include this location in the search then browse for the p2k drivers folder and select ok it will start installing then click finish. Again you will have to install do the same thing. Once everything is installed you will get a message your phone is installed and is ready for use. now go to p2kAE select phone services click on passwords then click on read from phone. There you are done. Not only that select video and you can increase the recording time of the video you can also record your videos in mp4 format. DONT MESS WITH ANY THING ELSE you will be in great trouble
Jan 19, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Safe password
A reset (but not a full one like factory defaults) this will change settings to the defaults, but not any saved data like files and folders. This may not solve your problem though, but it's worth a try. Go to Settings > Resets / wherever (you'll find it). If it works, all you'll have to do is set-up your theme again and any ringtones/alarms/backgrounds/flight mode/time.
Jan 28, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Create password to a folder
First, make sure you have a password when you login to your computer.
Right click the folder you want to protect.
Click "Properties"
Click "Sharing" tab
Place a check mark on the box that says "Make this folder private"
Click "Apply"
If you don't have a password assigned to your account, there will be a popup box that will ask you to assign one. It must be done if you want to make the "Folder" private, Click "Yes". You will then use the password when you logon to your computer.
To confirm it, Click the "Create Password" button and close the password window. Click OK.
The password will then be asked eveytime somebody tries to access your private folder.
Nov 27, 2007 | Computers & Internet
Password software.
hi there, if u want to do this you would have to go to the security section in settings and select the area you have this file and put on a lock with your secirity password on that particular area that u want hidden.To access this file or folder u would have to remember the code u used to lock this particular area. No one else would be able to access it but u once the security code is known only by u. Sam !
Sep 01, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
