Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
New board? AND how much would a new board cost?? And does it came with the stk's???..
    President:
  • 4,402 Answers
75 and yes
Posted on Jan 29, 2008
6ya staff
SOURCE:
Problem main power board stk 4191 print broken
If the printed circuit board is cracked depending on how fine the traces are will determine if the board can be repaired, if you are handy with a soldering iron there is chance you may be able to repair it, but if you are looking for a board replacement it would be next to impossible to find let alone the cost.
May 13, 2012 | Audio Players & Recorders
I have a 57F500 and my color looks like I'm watching a 3-D screen without 3-D glasses, have tried auto focus and that does not work. What should I do? Is this a cheap fix or should I just buy a new tv?
The tv have a problems known as a convergence problems,it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to fixed the tv 3D pictures problems.This problems are very common for DLP tvs and the tvs shops will cost around $300-350 for parts and labors.Will not get a new 50" tvs any kind for this price.
Jun 12, 2011 | Hitachi 57F500 57" Rear Projection...
I WAS TOLD I NEED A NEW BULB....IT WAS WORKING FINE AND THEN NOTHING...MAKING A SMALL CHIRPING REPETITIVE SOUND...YOUR THOUGHTS, THANKS
This problems,it is also the causes by the tv convergence board,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved this chirping problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Philips Magnavox 9P6034C 60" Rear...
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
There is a blue color shift to the right making people look like they have a blue shadow. Thanks. Matt.
it is a convergence failure
you need new stk chips to fix
this is complicated and requires soldering
typical cost 150 to 300
if you are crafty i can give you ideas on how to improve the picture without repairing but you will have to reach near high voltage lines, let me know if you feel so inclined
May 21, 2010 | Televison & Video
Blinking colors
there is a stk ic in the tv.which is located on the main board of the tv.that stk ic has gone faulty so u r getting this problem. u can get this new stk ic for replacement at  radioshack websites.
Dec 01, 2008 | Toshiba Televison & Video
Convergence Board (I hope)
check this out I have the same problem check your solder spot make sure the solder points are not touching one another, that could be one of the reason is doing this or just to make sure you can desolder the stk chips clean the holes where the pins go trough the board and power the tv with board and if the tv start fine if could be bad stk chips be very careful when desoldering or soldering good luck about another is not worth it they cost too much around 350-450
Oct 06, 2008 | JVC AV-48WP74 48" Rear Projection...
SD533HD5 Blowing Fuses
No lo creo ,ya que el problema puede ser el circuito horizontal checalo o manda la tv a un taller.
Mar 17, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Stk for sony 51'' tv
The parts don't cost too much, but do take about an hour to install. The worst part is in having to redo the entire convergence procedure after the new STK amps are in. Probably loking at $300 to 450 depending on what part of the country your in.
Jan 01, 2008 | Sony KP-51WS510 51" Rear Projection...
STK output devices PLUS
stk392-150 you need to replace bolth of them.
also for best repair
replace IC301 on (M)board part number 8-752-063-50 part is cxa1477as as a sony part its cost is $60 but the generic part will work fine its only $20.
regards
hope this helps
daniel.
Jan 01, 2008 | Sony KP-41T25 41" TV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
