VCR Records Both SP and SLP. Plays SP OK, but does a lot of rolling with SLP. VCR- SLP plays on other units with no problem. Any thoughts as to what the trouble may be?
DVD OK except that it does not record a full 4 hours on LP, but runs about 8 minutes short.
Thank you.Your suggestion prompted me to try more cleaning. Did so about 10 more times, had a slight flicker in playback. Still using wet cleaner as recommended in instruction manual. Hoe often should heads be cleaned?Thank you.Your suggestion prompted me to try more cleaning. Did so about 10 more times, had a slight flicker in playback. Still using wet cleaner as recommended in instruction manual. Hoe often should heads be cleaned?
You can't post conmments that contain an email address.
those don't allways work, as a mater of fact if it was a wet cleaner you shot the pinch roller as well... professional cleaned please mark post as fixya! those don't allways work, as a mater of fact if it was a wet cleaner you shot the pinch roller as well... professional cleaned please mark post as fixya!
if you use good tapes tdk,maxell you should have it professional cleaned once a year but that all depends how much you use it, if you record soaps everyday then 6 months Don't use a wet cleaner!!!!!!!!!!!!!!!!!!!!!!
Do you have a tracking control on the vcr if you do it should be centered during record It can be adjusted during playback to clear up the picture adjust it for the best picture
If you dont have a tracking control on the vcr then it may require a mechanical adjustment of the backtension or guidepost which requires special tools to perform
If I remember correctly, VCR players had three speed settings. SP-short play, LP-Long play, and SLP- Super long play. The vcr is supposed to be able to tell what speed the tape was recorded at, thus playing it back at the correct speed. If your unit has lost the ability to sense the speed the tape was recorded then you will have to set the speed manually, if possible. Other than that I would have to say it's time to get a new vcr.
U have play back problems on playback SP LP SLP modes tuggles problems.Try website like Remotes.com to buy the tv original remote,have these buttons to set the correct VHS tape play back modes tuggles problems.
:: Remote Control Overview 1 POWER Press to power the DVD+VCR on or off. 2 TRK+/- While a tape is playing, press to manually adjust tracking (i.e., to remove white lines from the screen). 3 0-9 Use to select channels and set menu items. 4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5 minutes, during VCR playback. Press to advance one frame at a time in Pause mode. 5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and backward at variable speeds. 6 MODE/REPEAT Press to set the Play Mode to Random or Programmed Play. Also press to set the Repeat Mode to Title, Chapter/ Track, or A/B Repeat (DVD only). 7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD only). 8 100+/3D SOUND Press to select cable channels 100 and above. Also press to activate the 3D Sound feature, which creates the illusion of surround sound with only two speakers (DVD only). 9 DVD Press to set the remote control to operate the DVD deck. 10 MUTE Press to turn audio on or off. 11 VOL +/- Press to adjust the volume. 12 STOP J Press to stop playback. 13 REW AA In DVD mode, press to skip to the previous track. In VCR mode, press to rewind the tape. Press and hold to scan backward during playback. 14 REC F Press once to start recording in the VCR deck. Press repeatedly to add recording time in 30-minute increments. 15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see page 15. 16 SETUP/ENTER Press to display the DVD+VCR menu system and confirm menu settings. 17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard Play) or SLP (Super Long Play). SLP is three times longer than SP. Also press to display DVD title menus (for discs with multiple titles only)
Those terms mean the speed that the VCR can record programs.
SP Standart Play >>> 120 minutes.
LP Long Play >>>>>> 240 minutes.
SLP Slow Long Play > 480 minutes.
hi sir
the speed in EP is differ from sp ,EP it is much slow then all quality would be less cause you are using less magnetic particles on the tape so here are many reasons for bad recording
first may be you have to clean video heads
or ,you have to clean the path of the tape in the recorder there are some metal guides that turnes with the tape to get it rounds the heads they may be dirty
or clean the capstain pinch roller and its metal roller that makes it run ( the capstain roller )
or you should have new heasd drum sir
regards
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen.
SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy.
HOPE this helps . . .
Jaszy
Has been cleaned about 20 times with wet head cleaner.
