Question about Sony PlayStation Portable (PSP) Console
SSID in the network setting what would i enter in the SSID? what is this?
  • 145 Answers
The ssid is the name for your wirelsess network, like your routers name, check your router configuration if you are unaware of the SSID
Posted on Jan 29, 2008
Tip
How to Connect Wi-Fi Connection
laptop user must know how to set up. to connect toWi-Fi locations. Using Windows XP in this tutorial, we'll go throughthe steps for setting up a laptop to access a Wi-Fi network. Some Wi-Ficards can be set to automatically detect and connect to Wi-Fi networks,though it is still important to know how to manually set up your Wi-Ficard to connect to a wireless network.
  • Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP keys are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their Web site or they'll give you the information when you purchase access.
  • Ensure you have a firewall program installed and running. This will protect your data.
  • Start up your laptop and look for the Wi-Fi network icon in the bottom right of the screen.
  • Click on the Wi-Fi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click onthe Properties tab
    This window shows the type of networking card installed. Click on the Wireless Networks tab.
    Once the Wireless Network Connection Properties window is open, you will have two options depending on how you set up your laptop. If you do not see any networks listed in Preferred or Available networks,you will have to manually add the SSID. Click on Add. You will have toenter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available Networks box.
    If you see the correct SSID showing in the Available Networks, then youn eed to click on Configure in order to enter the WEP key if that is required.
    In this window, enter the SSID for the Wi-Fi network you want to a ccess. Make sure you do not have CAPS lock or NUM lock while entering the information. If a Network key is required, click on "DataEncryption and then enter the Network key you have been provided with.Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly, a message will pop up and you will need to re-enter the key.
    Next go to Start - and where it says Connect To click on that and you should see choices similar to the graphic below. Click on WirelessNetwork Connection and it should work. Potential Problems & Their Solutions:
    Thereare occasions when the connection doesn't work. In these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall programd isabled, you will need to change your firewall settings. If your firewall program is not the problem, check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
    on Jun 24, 2010 | Computers & Internet
    Whats ssid mean.
    Hi
    SSID- Service Set Identifier
    An SSID is the name of a wireless local area network (WLAN). All wireless devices on a WLAN must employ the same SSID in order to communicate with each other. The SSID on wireless clients can be set either manually, by entering the SSID into the client network settings, or automatically, by leaving the SSID unspecified or blank. A network administrator often uses a public SSID, that is set on the access point and broadcast to all wireless devices in range. Some newer wireless access points disable the automatic SSID broadcast feature in an attempt to improve network security.
    SSIDs are case sensitive text strings. The SSID is a sequence of alphanumeric characters (letters or numbers). SSIDs have a maximum length of 32 characters.
    Dec 11, 2011 | Nintendo Wii Console
    No access in range check your ssid settings or move closer to an acsses
    Hi there.
    What it means by check your SSID settings is check that your network is broadcasting. The SSID is the name of a network, if it can't be picked up you may have to enter the name manually as the SSID does not always need to be broadcast, some people set up networks in this way to stop people knowing they have a network and thus make it more secure.
    I suggest you check your network settings on your computer and see if the network is broadcasting its name if not enter them as they appear on your pc
    Jul 04, 2011 | Nintendo DSi Black Console
    I do not know what ssid is
    An SSID is the name of a wireless local area network (WLAN). Your Wireless Network.
    Hope this helps!
    Don't forget to rate:)
    Dec 22, 2010 | Nintendo DS Lite
    Setting up wireless connection on aceracer, aspire sa90- wireless connection
    Check the Following
    1) Wireless Switch of the Laptop is off (Wifi is Off)
    it is located somewhere on the edge of the laptops
    or Fn+F2 might turn the switch ON and OFF
    2) The setting required to configure wireless connection
    Check the following steps
    Windows XP
    1. Click on the Start Menu, and click on Control Panel.
    2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
    4. Right click “Wireless Network Connection” and select “Properties”.
    5. Go to the “Wireless Networks” Tab
    6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
    7. Click “Add” to add a wireless profile.
    * Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
    * Uncheck the box “The key is provided for me automatically”.
    * Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
    * Push “OK”
    # Open Internet Explorer (with the computer connected to the Router)
    # Enter 192.168.1.1 into the Address Bar, push Enter
    # Leave the User Name field blank
    # Under the password field enter “admin”
    # Click “OK”
    # Click “Wireless”
    # Click “Basic Wireless Settings”
    # Enter a desired name into the “Wireless Network Name (SSID)” field
    # Write down your Wireless Network SSID, it will be used for later.
    # Click “Save Settings”
    For WEP:
    * Click “Wireless”
    * Click “Wireless Security”
    * Select “WEP” in the “Security Mode” field
    * Bubble “1” under the “Default Transmit Key” field
    * Select “128 bits 26 hex digits”
    * Enter a desired passphrase into the “Passphrase” field
    * Click “Generate”
    * Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
    * Click “Save Settings”
    Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
    My wireless has a WPA key and Abox is asking
    1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
    2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
    3. Go to "Network Settings" and then "Configure Network."
    4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
    5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
    6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
    7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
    Should work for either WEP or WPA
    Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
    We recently enstalled a Wireless-G Broadband Router (WRT54G2). Everything is fine trying to go from Desktop to Toshiba Laptop. I am on Comcast and can't get on line with the laptop. Our laptop keeps...
    6. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    · If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    · If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
    2. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
    3. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
    There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
    Jul 23, 2008 | Computers & Internet
    Wireless Home Network with 2wire modem
    hi dear
    try this
    1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
    2. Ensure you have a firewall program installed and running. This will protect your data.
    3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
    4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
    6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
    8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
      • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
      • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
    9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
    11. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
    oke post in me back
    i hope this usefull for you
    thanks
    cropp
    Jun 18, 2008 | Computers & Internet
    I have set up a home network using the Linksys wireless G router. I have networked one laptop to the network with no problem. A second laptop I am trying to connect just will not work. I need help,...
    hi dear
    try this way....
    oke post in me back
    thanks
    cropp
    Mar 18, 2008 | Computers & Internet
    Sony PlayStation Portable (PSP) Console Logo
    50 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
