Question about Gigabyte GA-8VM800M Motherboard
How do I disable vga on ga-8vm800m?
I have the opposite problem as list otherwise here. I install the nvidia 6200 pci card and the onboard vga will NOT disable. I can't find any way to disable it in the bios. I flashed it to version F2 and nothing new.
I removed the nvidia and plugged in a generic pci vga card and that didn't disable the onboard either.
Can I run a drill through the onboard chip or something to make it STOP!?!
I need the nvidia to support my new Acer 1440x900 monitor.
Thanks, I usually know how to do this stuff but this one is strange.
David.
  • david601 Jan 29, 2008
    Thanks for responding, I can't find where to disable the onboard vga in the bios. It looks like you can't do it by hand.
    I can disable the device in windows but it is still the boot display, even if there is nothing plugged into it.
    The best I have been able to get to is this: Boot with the nvidia card in - and the Acer monitor plugged into the nvidia card - nothing in the onboard vga port.
    No display on the acer until windows starts - then just blue (desktop color) - no icons. Mouse works and if I plug a monitor into the onboard vga I get a normal desktop from which I can drag things onto the acer.
    However if I open display properties and click identity - a big "1" shows up on the Acer.
    I can, however, set the resolution to 1440x900 and although it's not working the way it should, it sure looks great!
    Hope that gives some more insight. I believe I need to get to the point where the nvidia/acer combo is my boot display and the onboard vga goes sleepy. I still can't figure out how to achieve this.
    Thanks, this is still border-line fun, but it's going downhill fast.
  • david601 Jan 30, 2008
    Thanks for the info. I found this
    "Please install the driver from the following location:
    D:\Chipset\nVidia\WinXP_2K\Setup.exe (we assume your CD-ROM drive is D:)." buried in the manual also.
    Trouble is I don't have the CD for the mother board. It is in a Cisnet PC and there was no cd for the mother board included (I don't think).
    The Gig-byte.com site has drivers for this motherboard but no way to get the specific cd.
    Any suggestions?
    Thanks
During boot press DEL to get into standard BIOS settings, while in standard BIOS hold CTL key and press F1 this will alow hidden features to show in BIOS. Enter into Integrated Peripherals and you should now see a entry called INIT DISPLAY FIRST and you should be able to select between PCI Onboard and AGP (Depending on what you have installed). I have the same motherboard and had also upgraded to the 6200 which works great after finding the hidden BIOS features.
Hope this does the trick for you!
Posted on Jan 31, 2009
  • 145 Answers
Try byour Bios configuration for setting this up or alternately you should be able to disable it thru windows as well.
Posted on Jan 29, 2008
  • Patrick  Haines
    Patrick Haines Jan 29, 2008
    I did some research on your board and found that Gigabyte suggests using the provided XPRESS INSTALL CD to install NVIDIA drivers Some Nvidia graphics cards might have display problems under Windows 2000/XP.
    Perhaps doing things this way will set your nvidia to default.
  • Patrick  Haines
    Patrick Haines Jan 30, 2008
    I will look into this further, perhaps i can get this for you and somehow get it to you.
HP d530 sff with XP won't boot with NVS400 PCI card installed
display first going to your Nvidia card which is i think is faulty, however if you still want to attach it , change the bios setting, display first to onboard instead of pci
Jan 30, 2013 | Nvidia Computers & Internet
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
When i install my video card the screen is blank
Use onboard graphics and enter the BIOS/CMOS by pressing the delete key during boot.
Go through the options, some-where there, there should be an option to enable PCI-Express slot, PEG when one is inserted. This need to be set.
So onboard VGA is disabled unless PCI-E Graphics card/PEG is inserted.
damnor01
Jan 25, 2011 | PNY GeForce 6200, AGP Video Card
Nvidia 6200 gap graphics card not recognized under WIN XP
DId you hook up the secondaary power supply on the side a 5 pin 1/2 inch in width?
Nov 20, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
Video out switching between onboard and PCI-E
have you checked your bios settings? check there if you can disable your internall VGA card and only use your NVIDIA GeForce.
When you start your computer start BIOS to press DEL or F2 or F10 or F12, depends on your computer model and manufacture.
Oct 30, 2009 | Nvidia GeForce 7200 Graphic Card
I have D101GGC motherboard. I had Nvidia 6200 Geforce graphic card earlier but removed it now and installed VGA drivers. When I restarted the computer it was very slow and in the task manager ''Image name...
Did you fully remove the Nvidia software? Sometimes you need to remove the software for the card because it is trying to load when windows starts and cannot find the card. You can also try and disable the agp or pci-express slot in the bios and see if that helps. Also make sure that the onboard video can run the directX version you have installed on your system. If the Nvidia card runs on directX 9 and the onboard video can only run directX 8 and directx 9 is running on your PC then that will definently cause an issue.
Sep 05, 2009 | Intel D101GGC Motherboard
Want to disable onboard graphics to install and use pci vga card
During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
This will take you to BIOS, main setup panel for your PC.
There you can find and option for switching your main GFX card.
Options will be something like: onboard, pci, agp. You should choose
PCI.
Try doing this after you insert your new PCI gfx in your computer.
Good luck,
Milan
Jun 01, 2009 | EliteGroup P4VMM2 Motherboard
Geforce 6200 PCI is not running some games after installation
not sure of the game but pci graphics cards are not for gaming, that pc is a bit old- you need a pci express graphics card to game thses days. Also the 6200 is very weak as a gpu and very old- Nvidia is now in the 10th series of cards. Get a new computer definately with a core 2 duo cpu and at least a nvidia 8500gt grapgics card
Apr 10, 2009 | PNY GEFORCE 6200 PCI 256MB Graphic Card
You should be able to turn it off by booting the pc up into the Bios and changing your video settings to AGP.
May 17, 2008 | EliteGroup P4VMM2 Motherboard
Gigabyte GA-8VM800M Motherboard Logo
550 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
