Question about Aprilaire 550 Humidifier
Aprilaire550 water clicks on with furnance but wont click off with furnance replaced control transformer and soleniod and out door sensor
  • joconnll Jan 29, 2008
    this was an exsting humidifier
    1. soleniod yellow wires are hooked up to to h on the auto matic control
    the transformer from the furnance motor is hooked to R and C along with the transformer connected to a light for power
    water flow is not the problem
    it will turn on but wont shut down when furnance and furnance motor turn off .i have to turn switch to off on auto controller
    model 550 is connected to 1-model 56 automatic humidifier control
    pretty sure i got the wiring right
    refer to this diagram
    there is no diagram
  • 226 Answers
Did you just install this unit, or has it been working for a while and just stopped?
1. If you just installed it, the solenoid wires (yellow) must be hooked up to switch in when you have a call for heat.
a) use a current sense relay OR
b) connect 120V & neutral to "HUM" terminal and neutral on heater control board.
2. If it has worked before, maybe the saddle valve is plugged. Turn the "T" handle all the way clockwise, then all the way out CCW. You can hear the water start flowing. Loosen compression fitting at solenoid valve to make sure water is getting there.
3) Also, you must supply 24V to the circuit to open the solenoid valve. Check your wiring. It depends on the model what way to wire it and I cannot go into that here.
4) Testing: Turn off humidistat control. Turn on heat, wait for blower to come on. Turn humidistat control to test posn. Solenoid valve should click. This will put water into top of Aprilaire tray, after few minutes it will dribble out bottom clear vynl tube to the
Posted on Jan 29, 2008
  • earl llanera
    earl llanera Jan 29, 2008
    refer to this diagram:
Problem with 2 ....1 on each furnance Aprilaire 700 Humidifiers.. no fan no soilinoid click red light on one when furnance is runing they both worked last year
Odd for both to be out. Check the water supply sometimes corrosion or scale will block the saddle piercing valve. Run it all the way into the pipe. Usually need to spin the little valve handle clockwise. Then back it all the way back to full open and reset humidifier power and furnace power. After that may want to crack open water supply connection right before the solenoid at each humidifier to make sure water is getting to them.
Nov 30, 2013 | Aprilaire 700 Humidifier
Water to humidifer won't turn on.
Check if there is power to the solenoid valve, if ther is , then the solenoid is bad and must be replaced. If there is no power could be a bad humidistat or transformer.
Dec 19, 2012 | Aprilaire 600 Humidifier
My aprilaire 550 water solenoid is constantly clinking on and off while the furnance is running. What could be the problem
Hello, check for any loose wiring between the solenoid and transformer this usually causes the solenoid to click on and off.
Feb 18, 2011 | Aprilaire 550 Humidifier
Aprilaire 400 humidifier. No water flowing to the pad. I've checked the supply -- working. Replaced the solenoid, not working. Checked the electrical to he solenoid wnen system callilng for water -- no...
Check to see if you are getting 24 volts from the transformer, if not, turn off power to the transformer and check the resistance of the secondary side, if no resistance the transformer is bad and need to be replaced. Also check to make sure all the wires are secure. If you are getting voltage at the transformer then bring power directly from transformer directly to solenoid valve and it should click open and let the water through, if it does then either the sailswitch/current sensing relay is bad or humidistat is bad.
Jan 17, 2011 | Aprilaire 400 Humidifier
I installed a new Aprilaire 700 and everything looks normal except there isn't ant water flow, I am not sure if this is the solenoid or transformer problems?
Check if you are getting 24 volts at the transformer, if you are then appy power directly to the solenoid valve from transformer, you should here the solenoid valve click and let water through. If not replace the solenoid valve. If the valve works by giving power directly from transformer the check the wiring, humidistat, and current sensing relay/sail switch.
Jan 10, 2011 | Aprilaire 700 Humidifier
Water does not seem to be going through the unit
With the heat on, turn control knob back&fourth from test.U should here a click each time.If no click check hum transformer power.If it clicks flush out water supply pipe poss cloged.
Feb 27, 2010 | Aprilaire 600 Humidifier
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
Water does not pass through solenoid
Thanks for your question,
first you need to determine if you have 24 volts from the transformer, if you have knowledge of electrical meters then this should be fairly easy, if not then you will need to do a little rewiring to find out if it is the solenoid, first you will need to do is shut the power off to your furnace, then get some t-stat wire, long enough to reach from the solenoid to the transformer, splice together the new wire to the wire from the solenoid, now take the other end of the wire, take the leads off the transformer (low voltage side) and hook the new leads to it, make sure the water is on, now turn the furnace back on, and if the solenoid is good the water will flow, if it doesnt, then you will need to replace the solenoid, if the solenoid does work then you know your problem lyes with the Humidistat, and you will have to replace that, but you need to determine if you have 24 volts from the transformer first, hope that helped, let us know and please rate this, thanks again ,
Jan 25, 2009 | Humidifiers
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Knocking nosie when water enters humidfier
That would the the 24volt soleniod valve that the water line attaches to. Steve
Dec 20, 2008 | General Filters 1042-LH Humidifier
Aprilaire 550 Humidifier Logo
169 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
