Question about Canon PIXMA iP4300 InkJet Photo Printer
Substitute ink cartridges no longer work
I replaced my ink cartridges one by one (as they ran out), changing from the original canon cartridges to the substitute brand C&G. This worked until the very last canon one had to be changed - I found I needed to use an original for the BK8 for the printer to keep working. Then today, after a paper jam, I am getting the message "Some ink tanks cannot be recognized" and "Ink tank errors have occurred. Open the printer's cover and replace the ink tanks on which ink lamps are off." Holding down the Reset button for five seconds doesn't allow me to override these messages. Help please!
  • whiteme Feb 20, 2008
    I have the same problem. I refilled my cartridges (magenta, yellow, cyan and the BK) for the second time, but now the problem I think it's because the PGBK cartridge (it didn'r ran out of ink but my printer says it did and noy it's the only cartridge tha blinks red), but now I have the same message Ink not recognized. Can someone help us.
  • lazy tulip Mar 10, 2008
    I found an easier solution myself: if I use genuine cartridges for the PGBK and BK, I can get away with continuing to use the substitute catridges for the other colours.
I have the same problem and many Canon users , i try a trick that mayby solve this and last but not least ... Mayby the only cheap solution for all print users !! Substitute ink cartridges no longer work - jumping-smiley-004.gif
My problem .. was looking for a cardrige solution ( IP4300 ) because 4 (of 5) cardrige leds are dimmed off and need to be replaced . I just order 5 adopters and 5 new with chip for all the five cardrige . Problem : The chip uses memory and that makes it very hard to reset . But i have thinking .. mayby this is somthing ..
What you read is new, experimenting with this idea is all at your own risk !
Here is a simple markable solution Unique !!
A - First you need all 5 brandnew cardrige with chips ( please keep all ink preventions inplace )
B - You need is a 4 poles - 1.50 / 2.50 meter +/- telephone cable
C - (five) (new) OEM cardrige without chips
D - Tin and a somthing to solder
E - 5 old chips for adopting the connection outside the printer
F - A box for the 5 new chiped cardriges
Procudure :
1 ) Make of 1,5 / 2,5 meter a 5 pcs of 30 / 50 centimeter
2 ) Solder on each lengt a old chip (this is functioned as a adopter) but first remove all the (useless) electronic components and place them on the cardriges
3 ) Solder the other site of the cable to each new chiped cardrige cq / toner that still sits on the new orriginal cardriges ( our make a alternative contact if you dont want to solder )
4 ) Tape the 5 new cardriges together and *
5 ) Put it in the box and give it a save unremovable place **
6 ) Put the (5) oem cardriges with the empty old chips ) in the right ink location(s)
* ) Looking into the new cardriges : this needs a box because of the intervering with the led this not only makes it nicer but mostly because of the outside light influence .
** ) Dont turn the kid upside down our shake it . If you do , the led indicates that the cardriges are empthy our low and the countdown proces for the chip will start !
I wait for arrive of the new ones, anybody who try make a handshake !
See you soon
John
Netherlands
Posted on Feb 22, 2008
  • 1 more comment
  • Sirman Mar 10, 2008
    My surgestion i did for a solution for all printers isnt complete yet .. ( Canon IP4300 ) the measurering for the ink cardrige is layed outside , under the cardrige into the rail as (two ) sensors .. the LED in the ink cardrige has only the LED , not a sensor . the cardrige has a prisma on the bottom, the sensors receives the Ledlight if the cardrige passed .. This must overcome (to) for making a exclusieve methode of measuring . But this idea continiues on a nother printer website with a Ink Inkt cardrige replace solution for all printers ? ( canon IP4300 ) title. ..
    I saw the problem, mayby the flap of the CD print option is not closed enough and this can make the problem ( ) . The flap puches the rail upways, this also carries the sensor, and so if the flap isnt closed enough then the rail isnt come as high as needed to measuring the cardrige. I ame not able to test this now but let me know if that is the solution !
    I made a mistake in my earliere post , here my new post .
    I saw a solution with the ink recognise problems and mayby i have found the source of this mechanical problem very likely the flap of the CD / DVD print option is not closed enough ( ) . The flap puches the rail upways, when open but this also carries the sensor and the reason if the flap is not closed enough the sensor in the rail isnt become as low as this needed to measure the light throu the Prisma ( on the bottom of each cardrige ) , some vazeline our other means slide the pins / better . I am not able to test this today but if the solution ill be glade !
    Canon IP4500 IP4300 IP4200 , any CD DVD jet printer .
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
New Canon ink tank not recognized.
Check that the cartridge chip is not soiled or damaged in any way... Give it a quick clean, check that there's no ink anywhere else on the cartridge as there are sensor points that an LED uses to check the cartridge ink levels too.
If none of that works, phone Canon and request a replacement as some cartridges are known to have faulty chips.
Jan 29, 2009 | Canon MX700 Office All-In-One InkJet...
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
No colour printing
The problem with Canon printers sometimes is that, if you do not use original cartridges and put compatible ones, the printer will not recognise them. Even if you refill the originl ones the printer will still think that they are empty due to the microchip that every cartridge has. Try using original inks. If you already used original inks, then another reason might that the ink tubes have benn blocked because of dried ink if you haven't used your printer for a long time. Try performing a deep clean through the printer application.
Hope that helps
Apr 20, 2008 | Canon i80 InkJet Printer
The yellow ink doesn't print although the ink shows full
Hi there! are you using original canon ink cartridges? if so, your cartridge might have defects, try to replace your cartridge with a new one. If you're using compatible ink cartridges try to replace it with an original canon ink cartridge. Have a good day!
Apr 09, 2008 | Canon i860 InkJet Photo Printer
Ink carriage will not stop at centre to allow change of ink cartridges
hi star
Try this
After the printer decides the cartridge is empty it will start giving you warnings. Eventually it will give you a message to press the Stop/Reset switch for approx. 5 seconds to disable ink level monitoring on the empty cartridge. Ink level monitoring will be re enabled if a new OEM Canon cartridge is installed. There is no way to reset the chip on the cartridge but you can replace for new ink
oke
cropp
Mar 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Cannot recognize ink cartridge
I had the same problem. I was using original brand cartridges and it was still not working. Here's how I got it to work. I recommend doing each step and then trying to print a test page to see if it is working.
1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
3. From the same menu I also ran "Clean Print Cartridges"
4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Good luck. Hope this helps.
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon ip3000
try putting back in your old cartridge, If it works it means your new cartridge is defective or is not an original cartridge.. Newer printers have an upgrade in the firmware to detect Generic compatable cartridges or refilled cartridges and they claim the fail safe is to prevent damages to your printer.
Jan 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP460 cartridge error
"Verify that you are using Canon(TM) cartridges. The technology has progressed to where they have modified the ink to be identified by their printers. You cannot currently use refill cartridge inks to refill Canon cartridges. If that is not your issue, then try removing and replacing the cartridge(s)and reset the ink level indicator.
Lets hope for the best!
Regards,
Eagle"
Honestly.. There is absolutely no way for Those Canon printers to "look inside" or "Detect" the formulation of ink inside the cartridge...
Canon CL-31, CL-41, CL-51, CL-52 Print cartridges have the highest electronic _Failure_ rate of anything other inkjet cartridge on the market. Canon is aware of this. Replacing the Cartridge is the only sure-fire way of fixing this.
*sometimes the printer will tell you its the color cartridge, when in fact its the black cartridge. its advised to replace them both during these error messages.. it'll save you a trip, and the customer service rep's head. haha"
Using an Aftermarket or "re-filled" canon original cartridge is a sustainable resource for anyone looking to re-use an end-user item, and save money in this "tied-selling" market.
I proved you wrong by replacing my inkjets with Oringinal Canon PG-40 black, and CL-41 color cartridge. I ran them until they were empty. Bypassed the Ink Metering System explained to me through the canon software provided during the printer installation, and continued to print with them until they were 110% bone dry empty, laying absolutely no ink on the page. this took approx. 3 hours from perfect start, to finish.
If "canon printers have progressed so much as to distinguish formulations of ink" then.. this canon sure was the PICK of the litter. it continued to print *** as the day it was purchased, while not laying a single droplet of ink on the page.
get a life. stop dissing the aftermarket with your un-supported facts!
reguards,
inkjetech_007
Oct 10, 2007 | Office Equipment & Supplies
Canon PIXMA  iP4300 InkJet Photo Printer Logo
276 people viewed this question
old marine
old marine
