Luxman DAT Recording problems
Getting drop outs in split second intervals when I playback tape after a recording is made. These are new DAT tapes
Also tape rewinds very slow. FF works ok
Please advise
Thanks very much
Brian
  • Brian Stoutenburg Jan 29, 2008
    Hello
    Thanks for your fast reply to my questions
    I tried what you said about ff the tape and then try recording. I can't play my recording to test for drop outs because the tape won't rewind to the beginning.
    Are there belts that may need changing?
    Thaks again
    Brian
    Thanks for all you great advice
    Brian
  • 1,512 Answers
If the tapes you are using are "tight" it may be causing both the drop out and rew problems. Always a good idea when you buy fresh recording media to ff then threw it through to ensure that the tape is layered flat. they can tighten up in transit sometimes in shipping from manufacture. The unit will need some service work done also. A head clean could also help with the drop out. Use a Chamois tipped head cleaning tool to do thisusing iso alchol only AND A VERY GENTLE APPROACH. The drum heads themselves are very small and VERY FRAGILE!! Easily broken if you do not clean the correctly. Take it to a vcr/video camera tech for a clean and service of the tape path.
Posted on Jan 29, 2008
  • 3 more comments
  • Graeme Ross
    Graeme Ross Jan 29, 2008
    Check to see if other old tapes you have perform the same way in the unit. This may tell you if you are suffering a tape problem.Good Luck
  • Graeme Ross
    check out
    http://www.thevintageknob.org/LUXMAN/KD1...
    The transport used in yo deck was built by sony. Same as used in the DTC-1000ES
  • Graeme Ross
    and here is a good thread on mechanical problems these old girls may have. It is worth getting going again. Probably has dried grease problems in the reel assemly/failing belt/reel brake jammed. Up to you to go the mechanical approach and see what you can find. OR take it to a sony guy that knows camcorder chassis. Very similar technology
  • Graeme Ross
    or finally... phew... http://www.manualsparadise.com/ShowProdu...
    to pay for some service bulletins that apply to the reel brake locking on. Good Luck. I know i didn't fix it for you but a "Fixya rating would be great for the effort to find this out for you ;)
  • Graeme Ross
    oops forgot the mech thread http://www.diyaudio.com/forums/showthrea...
    last word :)
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
"Remove the cassette"
I only got the problem when the tape was bad. Usually the ribbon got folded, or was very wrinkly looking. Eventually I found out the drive was bad, and had to have it replaced.
May 08, 2010 | Canon XL1S Mini DV Digital Camcorder
Sony TRV460 D8-->Hi8 switching
I too was having a problem playing back my 8mm in my TRV460. The audio and video was both very glitchy. I tried what dyz66 said and rewound to the start of the tape,and then recorded about 10 seconds of meaninless video. After that the whole tape played nice and clear. Thanks for the idea. I believe from here on out I'm going to buy some new tapes to try and avoid this.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Audio dropout
take it or ship it to video tech service. they will clear it and go from there. it may need some tension adustments in addition. The guy there is super cool.
Aug 18, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Auidio drops
while your monitoring the sound when recording it cuts out or while you playback the tape it dropps out? if it's noticed during playback it's one 3 things. the heads are dirty, the tape tension is low or the heads are bad. send it to video tech service in sacramento. that guy is super cool.
Jun 20, 2007 | Sony Handycam DCR-TRV900 Mini DV Digital...
VCR recording
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen. SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy. HOPE this helps . . . Jaszy
May 29, 2007 | Maxell 10 Pack T60 Blank VHS Tape PI PLUS...
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
272 people viewed this question
 Grubhead
Grubhead
