Question about HP Photosmart 435 Digital Camera
Hp Photosmart 435 Digital
When I open the lens door on the front of the camera to turn it on the light flashes green then goes red no power. I have changed the battery and the memory card and the camera is only about a year old.
  • 18 Answers
SOURCE: HP Photosmart M22 Digital Camera
From the HP website:
Please, perform a camera hard reset. To do so, follow the steps below:
  1. Turn off the camera.
  2. Remove any memory card installed.
  3. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
  4. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
  5. Verify if the camera works without an optional memory card.
Hope that helps.
Posted on Feb 21, 2008
Agent Allan
  • 480 Answers
SOURCE: camera will not charge error
Hey jrforestgimp,
What this error code should mean is the camera can't determine if the batteries are rechargeable batteries or not. This happens when the charge on the batteries falls below 1.1 volts, because the camera can't detect what kind of batteries are in the camera when the charge is below this threshold. The way to remedy this is to either charge the batteries in an external charger, or buy new batteries. I hope this helps!
Go Ahead. Use Us.
Posted on Jun 18, 2008
  • 75 Answers
SOURCE: HP photosmart 435 digital camera
Try going to the HP website, and downloading the new drivers. If you are having a problem with it, that could be the only way to get the computer to recognize the camera. Good luck.
Posted on Jan 29, 2009
  • 11896 Answers
SOURCE: where can i find a manual for a hp photosmart digital camera435?? -
Copy and Paste above link in your address bar to go to your manual
Posted on Aug 24, 2009
  • 93776 Answers
SOURCE: hp photosmart m737 digital camera displays lens error m730-022
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Posted on Feb 22, 2010
  • 11967 Answers
SOURCE: how do you unlock your memory card in hp
Move the slide switch on the side of the card.
Posted on May 06, 2010
0 characters
1 Points
I want to transfer pictures from my hp 435 camera to memory card,, how?
Connected the camera with the USB cable at pc, open Explorer pc program to view like a "external device", select your files and copy/paste en each folder. Other way could be using some external device to your SD Card.
Additionally, its possible that find other details in this link for HP PHOTOSMART 435 MANUAL User Guide for HP 433 / 435 / 435v / 435xi
Keep us updated.
Sep 29, 2011 | HP Photosmart 435 Digital Camera
I have a HP camera CW450t camera and cannot turn it on with the power button on top. I know the batteries are good because I can turn on the camera with the review button and review the pictures that I...
I had the exact same problem. What I found out was that certain types of batteries have more power to power the camera and make sure the batteries are brand new because they might have been sitting in your cabinet or where ever and run out of power and not be able to open the lens or turn the power on, and the manual (disk) that came with the camera says not to take the batteries out if the camera's on and if your lens isn't opening properly it's because your batteries are low on power. Well I hope I helped. Bye.
Dec 27, 2010 | HP Digital Cameras
Where can i find a manual for a hp photosmart digital camera435?? -
Aug 24, 2009 | HP Photosmart 435 & HP Photosmart 145...
My lens is saying lens error m425-14 (7f80)
Mar 11, 2009 | HP Photosmart 435 & HP Photosmart 145...
I have a hp m425 photo smart
In what way do you mean broke eg lens shattered or it wont zoom , if its not physically broken  try tapping the lens gently in the opposite direction to which it fell.This should realign the gears
Sep 10, 2008 | HP Photosmart 435 & HP Photosmart 145...
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Aug 23, 2008 | HP Photosmart 435 Digital Camera
i still can't solve my problem with my camera.
the screen still displays a red color
Feb 21, 2008 | HP Photosmart M22 Digital Camera
My camera stop working
When I open the lens door to turn on the camers the green light flashes on then off no power
Jan 15, 2008 | HP Photosmart 435 Digital Camera
HP Photosmart 435 Digital Camera Logo
20 people viewed this question
Top HP Digital Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Digital Camera Expert? Answer questions, earn points and help others
