Question about Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
Admiral electric range with self cleaning oven
After locking the oven door and running the self cleaning. I cannot get the oven door to unlatch. When I close the lever to lock it, the door locks but remains latched when I move the lever back. Something is not moving to totally unlock the door.
Please adivse
  • 2 more comments
  • gcato1 Jan 30, 2008
    It has now been 24 hours and the door will still not open.
    I did try to open it while it was still hot and the lever would not even return. But now that the lever has returned, it is still latched. It acts like it is almost free but I am afraid that if I pull any harder, I will break something.
    Anymore suggestions?
  • Anonymous Mar 14, 2014
    Oven door won't unlock. Had a power outage and now it is locked when the power went back on.
    the self clean won't start and now the door won't open
  • Anonymous Mar 24, 2014
    I have a GE Spectra electric oven model JBP82SF1SS. I tried running the self-clean. When I closed the door and press start, a flashing sign "locked door" appeared. I tried to cancel but the flashing sign remain and I cannot open door. I turned-off breaker and back on but the problem persist.
  • 105 Answers
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
    Sergeant:
  • 201 Answers
Hey there gcato1, your problem is actually a protective feature designed to prevent you from getting burned. The self cleaning feature runs at extremely hot temps. Until the temperature reaches a safe level, the oven door will remain latched. Be patient and the problem will solve itself.
Posted on Jan 29, 2008
  • Devocap
    Devocap Jan 30, 2008
    Hey there gcato1, I will suggest that you unplug the unit and then plug it back in. It may reset the feature that has been keeping it locked. Good Luck!
  • Devocap
    Upon further investigation, it appears there is long metal arm extending from the back of the stove which has had some problems in the past with getting, stuck or unseating from motor drive. Apparently if you remove the back panel of the stove, you should be able to locate the small motor with an arm extending from it. The bad news is it is apparently quite difficult to rotate the arm and hence release the door. The cost of repair is substantial due to the replacement of the whole assembly, so self repair attempt may be worth a shot. Open the back. Take a look and see if you are up to it. Good Luck!
Oven door locked electraulux gas slide in range
Try to turn the circuit breaker off to the home for about 10-15 minutes, then retry the unit. If the door does not unlatch then either the door latch assembly or main control board need to be replaced, since they are not communicating correctly. Consult a professional at that point to be safe.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
When I set the self-clean cycle, all seems to be working - the light goes on, door locks, but no heat. Fuses appear to be okay.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Sep 26, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Can not open the door of the self- cleaning electric Range after cleaning operation
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures
Mar 11, 2010 | Kenmore 99123 Electric Kitchen Range
How to unlock my door after self cleaning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Jan 26, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Oven door is locked
the oven door should only unlock the door when it deems the temperature a safe temperature.. there are 2 other possible reasons.. the door lock motor could be bad.. or the control is bad.. you would need an electric volt meter to test to see which it is.. if you need further assistance please ask b4 rating
Apr 09, 2009 | Amana ACS7270AS Electric Kitchen Range
I have a KGST300 gas freestanding range. I tried to run self clean, but immediately after starting I canceled, as I forgot to remove the oven racks. The process stopped, and the door unlatched, but I...
By the way the door lock error will stay there until the oven cools. Once it has cooled it will go away. the reason is in a self clean the oven is supposed to get very hot to clean. The door lock is for your protection. once it has cooled down enough the door lock will go away.
Dec 01, 2008 | KitchenAid Kitchen Ranges
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Oct 02, 2008 | Kitchen Ranges
Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range Logo
1,231 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
