Rca dcr8060n dvd tray will not open - Televison & Video
  • no 13 Apr 21, 2008
    The tray will not open on the DVD player. The display just states that it is locked. My young 10 month old may have done somethin to the tray.
  • Anonymous Apr 23, 2008
    The tray will not open and rattles. How can I fix this?
    Problem Solver:
  • 10 Answers
Your kid did not damage it, try this, apply pressure slowly to the top of the unit about 3 inches from the front of the unit centered above the tray. Press the eject button, I am betting it will open. They seem to have used really crappy dvd drives in this unit and the top magnetic mount does not release cleanly, therefor causing the unit to hang when the door attempts to open.
Posted on Jul 13, 2008
Panasonic DMR-HS2. Why doesn't DVD tray open or close and why is there no audio/video output?
Tray movement failure can result from a weakness in electrical or mechanical components.
"hooked up both RCA audio/video outputs to my HDTV". Often the RCA outputs are coded R (right audio), W (left audio), and Y (video). If these are not connected to corresponding inputs on the rear of the TV, you will not hear/see much.
Do I need to use a(n) RF modulator to connect to my HDTV to see video? No
Mar 04, 2016 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Rca dvd player stuck
There are a number of possibilities, jammed gears caused by a disc or gears out of time, some have a very small loading belt located under the draw in most cases, excessive ware and tare on plastic gear linkage.
Sep 05, 2012 | RCA Televison & Video
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
I have an RCA DVD/VHS combo with TVG. The DVD
This is a work-around rather than a solution. We put an audio CD in the tray and after closing the tray the unit begins to play the music. After waiting a few seconds we open the tray and quickly substitute a DVD and it loads OK. We had also tried cleaning the player to no avail. The CD approach is a pain but it does allow us to play DVDs. Jim
Jan 15, 2010 | RCA Televison & Video
DVD stuck in player
make sure that the dvd is unplugged from the outlet and remove the screws of the cover, you should be able to access the dvd from inside the player without the cover on.
I hope this helps
Jun 28, 2009 | RCA DRC225N
Dvd
If there is any pin point holes around or on the disk tray then take a push pin and push in the hole the tray should manualy pop open. from there you would have to pull the tray completely open. if not. it could be a faulty motor. in which case you will have to get the tv or dvd player replaced. not worth fixing if it is under warrenty. if not. you are better off letting go and moving on.
Feb 15, 2008 | RCA D61W136D 61 in. TV/DVD Combo
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
DVD Tray won't open.
Replace the DVD unit part#265278. It shows as NLA but do some searching.
Feb 01, 2007 | RCA 24F501TDV 24" TV
Televison & Video Logo
269 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
