Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
HEPA FILTER REPLACEMENT
I HAVE LOST THE MANUAL AND DO NOT KNOW HOW TO REMOVE THE HEPA FILTER DOOR. CAN ANYONE EXPLAIN HOW TO DO THIS FOR THE SEARS KEMORE CANISTER MODEL 116.25513506. THE MANUAL IS NOT AVAILABLE FROM SEARS.
  • tessaca Jan 29, 2008
    There are grey tabs but they do not allow movement if pushed in. Can you provide more detail.
    President:
  • 1,673 Answers
Looks like there are is an 2 indentations on the back, these are tabs, push them in and push the cover up, it should come off.
Posted on Jan 29, 2008
  • Lauren Junge
    Lauren Junge Jan 29, 2008
    The tabs are like hooks and hook under the edge, so you have to push them in to clear that edge.
My Hoover Elite Rewind just lost power while vacuuming and wont power back on?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Squeeze out the filter and allow 24 hours to air dry.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Oct 07, 2014 | Hoover Vacuums
My Hoover Elite Rewind just lost power while vacuuming and won't power back on?
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to change the hepa media filter, where does it go. I can't find my manual
Unplug your cleaner first!
The HEPA media filter Bissell # 3205 is behind the door on the front of the machine just below the dirt cup. Just open the door, remove the filter and replace it with a new one.
May 15, 2010 | Bissell 6596 Bagless Upright Vacuum
How do you remove the HEPA filter on Dyson DC07
I use a screw driver to pry them up.
Joe
Nov 07, 2009 | Dyson Vacuums
Cleaning filter on the Dyson Slim
You don't have to clean the HEPA filter (underneath the canister in that clear part) - if you break that clear part you will cause damage to the machine and it won't **** anymore as the air will escape. There is no need to remove it or replace it, it is a lifetime filter. You only have to clean the blue filter that is inside the top of the canister/dirt bin.
Mar 24, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Mar 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hepa filter on dyson dc01
Not sure about you model, but some of the dyson's have the hepa filter under the dirt container. Remove the container, there is a cover that comes off and the filter is under that cover.
Apr 20, 2008 | Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
567 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
