I need information about the connection of fax and printer
You can connect it to your PC with a USB cable, and you'll need to install Brother's printer driver to run it. You can download the driver at http://solutions.brother.com According to the manual it will run on operating systems up through XP. There's is no data on Vista or Windows 7, but an email to Brother customer service should answer that question. Need the manual? You can download/print it at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
SOURCE: Brother Intellifax 770 - how to connect to PC?
The intellifax-770 deffinetly cannot connect to a PC. There are several other models that can, but not this one.
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is
connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer
automatically now.
Now you will be able to print.If not then follow the following steps.
Please be informed that any
Printer Driver software depends upon the hardware make and Operating System.
You need to know all these information's to do get going.
Please find the Driver software's of your printer inside the installation disk
provided with the Printer at the time of purchase. As you have not mentioned
your Printer make I am unable to give you the direct download link. However you
can download the same by visiting the website of the company that manufactured
the Printer.
Even here you need to be careful
to download the correct software for your PC. You need to be exact with the
Printer Model number and the OS that you are using.
To install just Double clock on
the driver setup.exe file and go on clicking 'Next' until you get the 'Finish'
option and restart the PC.
If you feel that my answers have helped you getting
solution to your problems then please give a vote for best answer.
Thanks.
