We bought this phone in Miami and we live in Brazil. The phone simply will not ring. What can we do? We have visited our local Claro (service provider) and they worked on the phone, it rang for one day then stopped again. they say the problem is the phone?We bought this phone in Miami and we live in Brazil. The phone simply will not ring. What can we do? We have visited our local Claro (service provider) and they worked on the phone, it rang for one day then stopped again. they say the problem is the phone?
You can't post conmments that contain an email address.
Try the buttons on the side. Open the phone, On the top of the phone, left side, increase the long button by pushing the top of the long button. Let me know if this works.
To pair the Jabra with a Verizon Wireless phone, the phone must have
Bluetooth. Bluetooth allows a device to communicate and transfer data
with another Bluetooth device without having to be physically connected
to it. The instructions for connecting the Jabra with the Verizon phone
vary slightly depending upon your phone model. Jabra headset
instructions don't vary per model.
Detailed instructions can be found by downloading the user manual from the Jabra support page. PAIRING IT WITH YOUR PHONE1 Put the headset in pairing mode- When you turn on your Jabra EASYGO for the first time, theheadset will automatically start up in pairing mode, i.e., it isdiscoverable for your phone. When the headset is in pairingmode the Bluetooth status indication on the StatusDisplay isflashing.2 Set your Bluetooth phone to discover the EASYGO- On your iPhone 4s, go to settings>General>Bluetooth and make sure Bluetooth is turned on.3 Your phone will find the Jabra EASYGO- Your phone will find the headset under name Jabra EASYGO.Your phone then asks if you want to pair with the headset.Accept by pressing Yes or OK on the phone. You may beasked to confirm with a passkey or PIN. Then use 0000(4 zeros). Your phone will confirm when pairing is completeand the Bluetooth status indication on the StatusDisplay willshift from flashing light to steady light and the headset voiceguidance will say connected. Manual pairing modeIf you wish to use the headset with a different phone, or if thepairing process was interrupted, you can manually set the headsetto pairing mode.Make sure the headset is on. Press and hold the answer/end buttonfor approximately 5 seconds until the Bluetooth icon turns froma steady light to a flashing light. Then repeat steps 2 and 3 in theabove pairing guide.Connecting with your phonePairing is only needed the first time a headset and phone areused together. When the headset and phone have been pairedonce, they will automatically connect when the headset is on andBluetooth is activated on the phone. The headset can be usedwhen it is connected to the phone. If the devices are paired, butdo not immediately connect, tap the answer/end button. Whenyour headset is connected the Bluetooth connection icon in theSTATUSDISPLAY WILL BE CONSTANT ON FOR 3 SECONDS andthe headset voice guidance will say connected.
1) Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
2) Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
3) Release the power button.
4) Navigate through your cell phone "Settings" menu and ensure your "Bluetooth" or "Hands-free" section is set to the "On" or "Active" mode.
5) Choose "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
6) Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
7) Select a "Connect" or "Pair" option once the Jabra headset name displays on your cell phone.
8) Enter the default passcode by entering "0000" on your cell phone keypad.
9) Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Generally speaking, bluetooth connects like this: 1:Turn on the bluetooth device (phone). 2: set phone to search for the bluetooth headset. 3: Turn on the headset 4: when it finds the headset (you may need to try TWICE), enter 0000 to the phone as a basic password. The two should link. Your headset guide may specify a different password - use that. The headset may require you to hold down a button to help the search - do what the manual says.
abra burst onto the audio microtechnology scene in the early 1980s,
gaining initial attention for its Macintosh EarPHONE telephony
products. Jabra's cell phone
Bluetooth headsets have also garnered wide acclaim for their sleek
aesthetics and compact form. Jabra Bluetooth headsets can be connected
or "paired" with virtually any cell phone by using a few simple steps.
goes off.
Step 2
Hold
Step 3
Step 4
Step 5
Elect to "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
Step 6
Step 7
Select a "Connect" or "Pair" option once the Jabra headset name is discovered and displays on your cell phone.
Step 8
Step 9
Ensure
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
You have to pair the two devices first.
Use your phone to detect other bluetooth devices, when it finds the model Jabra you are using select it. Reset it before you start.
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at [email protected]
