Question about AudioBahn AEQ6 5-Band Car Equalizer
INFO:EQ HI THERE I HAVE AUDIOBAHN AEQ6 AND I WOULD REALY LIKE SOME HELP HOW TO IN STALLING IT? ON THE UNIT WHERE THE WIRES COME OUT AND IT SAYS "GND,SENS,BATT" WELL I KNOW WHAT THERE OTHERS SAY BUT WHATS "SENS"??? AND HOW DO I GO ABOUT WHERE TO INSTALL IT?? THANKS AGAIN HOPE TO HERE FROM YOU SOON AGAIN THANKS.
    Problem Solver:
  • 5 Answers
Sens is ussually a term for the more common "remote
" wire. You will need to look at diagram to be sure but Im about 99% positive that in your case the sens wire is the input wire for a switched ingnition, especially since you say it is located next to theGND and BATT wires. You will need to connect the SENS wire to 12v hot, similar to the BATT wire but this wire will need to be switchable, meaning it can be turned off and on, say when you turn your key on and off, or when you turn your radio on and off. For example, the remote wire output from the back of an aftermarket cd player, ussually blue with a white stripe or just blue, or the ignition wire of your aftermarket radio, ussually red, or the ignition wire of your factory radio, or any 12v switched fuse in your fuse box. They will all work. In a worse case senario, if you have trouble locating a true ignition wire, there is a short cut. If the EQ has an actual power button that you can turn on and off, you can make this short cut by wiring the SENS wire to the 12v hot BATT wire. Then you can manually turn the eq on and off with the power button. Just remember if you wire it up this way, and forget to turn it off when the vehicle is not running, after about 24 hours or so, the battery may be drained somewhat, and you'll have trouble starting your vehicle. This is definately your last option.
The BATT wire needs to go to the hot in the BATT or the memory ( yellow) from the aftermarket CD player. The GND needs to be connected to anything metal in the car that is connected to GROUND, for example the frame work of the dash board that is metal, or the ground wire from your aftermarket radio ( black).
The rca input will be the RCA;s coming from your cd player.
the rca output will go to your amplifier.
Placement is completely up to you.
If it came with brakets, placing it flat against the underside of the dash board should work. But it could litterally be anywhere, and any where where it will suit your needs. Glove box works well too, so does in side the arm rest console, if you can get you wire to reach good luck.
Posted on Feb 02, 2008
Wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Aug 01, 2009 | Car Audio & Video
KENWOOD 9-BAND EQ DOES NOT POWER ON, i have all 3 wires connected and nothing, eq does work i had in different car, but wont power on at moment
Hi try earthing the chassis of the unit as well to ground with a wire. Sometimes units have to grounded all round. Check the inline fuses also to be sure
Best of luck
Jul 24, 2009 | Car Audio & Video
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Need info on wiring for audiobahn aeq6q 5 band equalizer
Yes, This connects to the Blue Remote Wire. This will allow the EQ To Power on when in ACC or Start on the Ignition. Please Rate My Response! Thanks!
Feb 03, 2009 | AudioBahn AEQ6 5-Band Car Equalizer
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
Pyramid eq 906vl no remote lead
that unit use just two power wire you have to connect it to an accessory power source that turn of by your car radio
Oct 08, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
Audiobahn dvd player and monitor for car roof
hi i bought 3 units of this on ebay for 7$ bucks fully working missin remote control if u want i can sell u one head unit for 10$
Jul 08, 2008 | AudioBahn AVM372DVD 7 in. Car Monitor
Power cable for A1451
yes if you will open up the unit and look on the circuit board that it connects to it is labeled plain as day what each plug is (b+, gnd..) find that out and thats how ya do it
Apr 15, 2007 | AudioBahn A1451 10-Disc CD/DVD Changer
AudioBahn AEQ6 5-Band Car Equalizer Logo
195 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
