Question about RCA D52W19 52" Rear Projection Television
Burning smell have a RCA D52W19 HDTV just got back from repair shop for a new power supply. Now makes a high pitch noise and trys to start 3 times and fails. smells like it is burning.
  • dani79 Feb 02, 2008
    We have the same model number and have had problems with the screen going black especialy during commercials for a while. Now the tv wont come on. When we hit the power button the green power light will flash 3 times and then stop. Worth fixing or start over with a new tv?
  • 97 Answers
The power source is trying to start and it sint. the lamp is done with because thiese tvs need high voltage. its probably melting pallastic around it . get rid of this, much money to fix up and or try getting itn fixed if stiill have legeble warranty
Posted on Jan 29, 2008
My RCA hdtv D52W19 smells and has a crackling noise when i turn it on
Check for bad connections at a capacitor near the flyback & flyback pins - at the power supply board. Also possible - 1 or 2 bad capacitors, they can be found by the blown out top. In our shop this is a $240 repair. It is possible the red picture tube has broken and is arcing.
Jan 21, 2011 | RCA Televison & Video
I have a 60 inch crt RCA that will not turn on the green lite come on and then goes off about 3 or 4 trys and the off for good I could smell electronics type burn odor also. I have had this similar...
The most likliest thing is the flyback needing replacement its 259296 flyback if you have a D52W19 you can get one at the following link which includes detailed instructions on the repair.
http://servicemanuals.vstore.ca/
Jun 24, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 "crackles" and smells like its burning
Hello pmzone_guard, This problem is quite common in this TV it's due to a capacitor in the power supply being overloaded. The chassis model is a ITC222. The capacitor is located on the deflection board which is part of the power supply and should not be touch by someone that does not have TV Repair Experience, due to the fact that this area of the TV is the most dangerous. I would suggest having a qualified TV repair technician do the repair on this TV. If the problem is just that one capacitor the part will cost about $2.50 at the most, so the charge will be the cost of the part plus the labor involved. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 14, 2009 | RCA D52W19 52" Rear Projection Television
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
My tv has a dinosaur in it.
Its a raptor most likely. But seriously, when these RCA TVs go into shutdown or fail to power up, they will try 3 times to re-establish operation. Your problem can be caused by a number of circuits. The power supply itself may be bad or the high voltage/ deflection circuit. You can visually inspect the circuit board. Some failures in these TVs will cause obviously damaged components like burned resistors and the like. The problem here is that most anything that will fail will cost some serious money. Expect to spend $300-500 to repair it or consider replacing it.
michtech
Feb 15, 2009 | RCA D52W19 52" Rear Projection Television
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
