Question about MSI RS482M4-ILD Motherboard
No boot with integrated vga
All parts are new....but nothing seeing in monitor...power is on and all connectors is ok....what can i do?what kind psu is correct?
  • realxvirus Jan 28, 2008
    i forget say...there is no error beep sound or nothing...
  • realxvirus Jan 29, 2008
    thanks trying...but all parts is seated correctly and i try four different memory types...Everything should be ok,but something is still wrong...i don't have anymore ideas in my head... :(
    Sergeant:
  • 201 Answers
Hey there realxvirus, I would begin by reinstalling your ram, ensuring you are seated correctly. Your motherboard has a specific setup for high performance memory design. The ram you have installed may not be compatible with your board. Check here http://www.msicomputer.com/msiforms/k8tneo_ddr400_recommended.asp to ensure your ram is correct. I do not think the PSU is the problem assuming you have a 24 pin connection rather than the 20 pin, and power seems to get to the board. I hope this helps. Good Luck!
Posted on Jan 29, 2008
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
Thanks for using FixYa.
May 14, 2011 | Computers & Internet
My 3210 fails to start up the repair shop says it the motherboard replaced it and the cpu and the psu and it still doesnt start up any ideas
if you have change already the motherboard, cpu and psu here is what you need to do to check your pc by yourself and may be figure out what the cause of the problem.
1. connect the connector on your psu the motherboard. connect psu connector for hard drive, cdrom drive exhaust fan.
2. turn on the pc. look inside, if you see the led on the motherboard turn green then there's a power coming out from the psu.
3. hear the hard drive if its working, you can feel it vibrate.
4. check the little blower in the video card, if its spinning then there is supply in it.
when you turn on your pc the logo on the screen on the monitor will display. should you not see it, check if the monitor is plug in the ac outlet or the extension of your computer. if you see it then monitor is good. If this display followed by a dark screen with no signal display, then it means it is receiving no signal from your video card. go check the vga cable if its properly fix to the monitor and the video card. you can also detach the video card from the motherboard and reseat it properly. this sometime is the fix for no display.
If after booting after the logo, nothing else but dark screen, then is suggest you loosen the harddrive and reseat the connector properly, restart the system again. you can also check if the voltage from the power supply is dropping when there is a load in it. using a multitester test the 4pin connector. readings from the red wireshould be +5vdc and the yellow +12vdc. If its dropping then system will hang. check if there is shorted in your cpu, most of the time it is the blower or exhaust fan.
post back your findings so i can still help you out.
goodluck
he power cable on your psu and the plug to the ac outlet. turn
Feb 08, 2011 | E-Machines eMachines Desktop PC
Hi, i have an xfx radeon hd 5870 card.When i power up my system the fan on the card spins excessively fast and loud.Also the monitor goes blank. My lcd poster indicates 2a-2e which means when it trys to...
This may not be a card malfunction but a lack of power.
The XFX Radeon HD 5870 reqiures:
1) A system with at least a 500W power supply.
2) Two 6 pin power connectors.
Make sure you have a 500W PSU or better and that Both PCI-Express power connectors are correctly inserted. If your system still doesn't get signal then you're going to have to try another card to see if it's not your other components.
Jan 05, 2011 | ATI Computers & Internet
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
Display adapter corrupted nvidia geforce 7600 GT updates don't help at boot up display screen faded colour with many colums of !!!!, etc. and will only boot to welcome screen in safe mode then restart...
a 12 year old PC !!!
powers on, yes
all fans work, not stated and is 1st ,overheated is bad.
PSU fan, CPU fan and if present GPU fan all working perfectly
and heat sinks not packed lint as ALL DO 12 years old and never serviced. timely.
NO OS stated, you posted an old m7650n , PC. desktop
then fail to say its XP the dead OS and virus magnet?
no screen stated, is the screen old to, Monitor with old Dead
or near dead CCFL tubes (blackground)
what we do on all relics this old
1: test the monitor on a good PC?
or
2; test the PC on know good Monitor.?
easy no/?? simple tests, 1/2 the problem solved.
all that above from word "FADES" (wish could see it and watch)
lets say (i toss a coin) that the monitor is good.
PC bad.
PC needs a good power supply next.
what VGA jack are you using ,most desktop ,or many
have 2 jacks, one is main, board video
other is add-in board PCI card video, which one are you using
i cant see it.
ever see the PC run ok for a week? or just found this at garage sale. for $5?
matters big time as others tend to mess up parts inside guessing.
One error is not using the upgraded video card power aux jack
for 2 reasons, dont understand it, or forgot or the PSU doesnt
have that extra ATX2 wired power cable, rendering the aux vga card useless...... see how easy it is to mess up video.just that.
is the MOBO RTC coin cell good, over 2.9vdc with a meter?
if not get rid if that first. never seen one this old good , me.
then get the BIOS screens working first, forget the OS. for now.
then we can work that.. BIOS screens HOLD good.
no fade in BIOS??????
still has PS/2 keyboard, if yes, HP keyboard? still?
try another keyboard, in cases keys are stuck? !!!!!!!!!!!!!!!
if the screen does not fade in bios, then say that ,
as that is a whole other set of problems and causes.
facts: HP Pavilion Media Center TV m7650n Desktop PC this PC does have onboard mobo integrated graphic. runs the
(NARRA2-GL8E)
as seen here
https://support.hp.com/us-en/document/c01080282/
that GPU there is.
Integrated graphics using nVidia GeForce 6150SE
the page states
*Integrated video is not available if a graphics card is installed.
  • Integrated graphics using nVidia GeForce 6150SE
  • Up to 256MB (with 512MB or more PC memory)
  • Also supports PCI Express x16 graphics cards*
that 2nd bullet means main ram must be good. try swapping ram
if 2 DDR sticks try each one at a time, in bank 0?
if using express video now is the time to say. thanks.
Dec 30, 2017 | HP Pavilion m7650n (RF254AA) PC Desktop
Compaq Presario Media Center SR1750NX - Will not come up. Fan starts on high and stays there. No Keyboard lights flash. No monitor. No beeps. Replaced memory, disconnected harddrive, tested and then put...
the PSU has fan, does it spin and blow.
Seems to me. the PSU is bad. 5/12 is ok but there 20/24 pin connector is way more important that that legacy 4 pin .
my guess is the Cd driver ejects ok.
re-seated memory , i guess. (tried 1 at a time is the way !)
tried in bank 0 (lowest number) one at a time.
the voltage are here, do the bench test on it , all power pins.
see that 3.3v?
unplug it, jumper wire the correct 2 pins
pin 16 to 17 on modern PCs (24pin)
your PSU stays on, but some have really poor power checks.
so the unstated SCREEN , with power on last.
shows, no SIGnAL, no sync, warnings.? (or out of range)
no text ever. on said screen.
what video card is there, or is this onboard video.,
on mobo direct vga jack? yes it does but is there a addin video card there.? count VGA jacks, 2 means it has adding card.
onboard is here.
ATI Radeon Xpress 200 shared video memory (UMA)
http://www.pcdied.com/power.html
I think the PSU is bad, one other way it can go bad is to
incorrectly time the Power _OK pin, timing.(output)
see this many times, this pin tells the mobo power is ok.
if it sticks at ok, the Mobo can not function, if this pin lies.
the PSU tells the mobo power is ok
then if the mobo power regs fail, then the mobo sends
Power_on to false and the PSU shuts down.
in your case the Power_ok seems stuck ok. falsely.
or can be.
the thing to know is the power regulators are in the PSU and the MOBO, and both must be good.
or it will be dead.
we bench test all PSUs
and even swap them , to be sure it is ok,
if yes, ok then the mobo is bad (if all loads removed first)
all hdd,/dvd/cd drive. out. (cables pulled)
all addin cards removed ! all of them. if present (look for them)
all memory out and put back 1 by 1.
RIP MOBO
Dec 20, 2017 | HP Compaq Presario Media Center SR1750NX...
Hard drive won't read monitor
that would be a video card unless the video is builtin to the mother board . either way they can fail
Dec 17, 2017 | HP Axiom 60GB for HP Pavillion n5xxx and...
Brand new motherboard wont start up
try taking 1 stick of ram off the motherboard, and boot up with 1 stick in slot 1 or 2.
You should get some beeps, 1 is system Ok.
3 is usually RAM/Graphics problems.
Also try booting with the motherboard setup disk in the CD Drive, it may be looking for files to initialise the Board.
And the obvious, check that all cabling is correct from mainboard to front panel. Power on/off Reset et,c.
View the user manual to see if the board has any jumper/dip switch settings for different configurations.
Mike @ compurepair.
Mar 14, 2008 | Computers & Internet
EVGA 8800GTS g92 with ASUS P5VD2-MX SE
Suggestion 1: Try switching your Monitor's plug from one DVI to the other. This shouldn't do anything, because your graphic card should display the booting sequence on all connected monitors... however, doesn't hurt to try.
Suggestion 2: New graphic cards are quite a power-hungry monsters... are you sure your power supply is up to the task?
Your current configuration could help in this regard + the make, model and rated Wattage of your PSU.
Feb 17, 2008 | ASUS P5VD2-MX SE Motherboard
MSI RS482M4-ILD Motherboard Logo
63 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
