I had trouble finding one for my PoGo printer and finally found these people by calling Polaroid and being re-directed here. They may have adapters for the PoGo Camera also. The number is 1-800-765-2764 and listen for options.
Hope it helps and let us know if it works for you.
Download the "Polaroid Pogo App" from the Android Marketplace. This will solve the problem of the Pogo rejecting your phone. It also has other features like different "frame shots" or printing one picture over 4 sheets. Best of all - it's free!
You need to provide the passcode 6000 as shown in the Pogo manual.
If that doesn't help, make sure Bluetooth is switched on, on the phone. Also check the compatibility list of phones - mine's not there but yours may be : http://www.polaroid.com/compatibility
TO CLEAN PRINT HEAD, TAKE AN A4 SHEET OF PAPER CUT IT TO SIZE FOR THE POGO,BUT MAKE IT (3) THREE THIKNESSES THIK, FEED IT IN UNDER THE PRINT HEAD AND CLOSE LID, WHILE THE PAPER IS BEING EJECTED PUSH UP ON THE PAPER THAT IS BEING EJECTED WITH YOUR FINGERS, YOU MAY NEED TO DO THIS A NUMBER OF TIMES, BUT IT WILL CLEAR THE STREAKING. IT WORKED FOR ME AND MY POGO DOSE BRILLIANT PRINTS.HOPE THIS HELPS PEOPLE. JB
hello, i had this problem with my lg phone but i have found that if i change the picture name before printing it then will print via the bluetooth. hope that helps. sarah
you have to put the camera in view mode first ...and select pict bridge ..than follow the instructions on your camera ...probably will have to accept connection or confirm transfer ..
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
I have that camera and a new Pogo printer. To print, attach the camera to the printer with a USB cable. Make sure the camera's "take pictures/view pictures" slide switch is in the down view pictures position. Turn on the printer, turn on the camera. Select the picture to print. Press the camera's FUNC SET button. Accept the default settings and press the FUNC SET button again. In a few seconds, your picture should start to print.
