Question about Sanyo DS25390 TV
No real problem yet
I would like to know if my sanyo 25 inch..model #25390 is considered digital?
Folks, remember that the DTV converter boxes are only useful for off-air reception. You don't need one (and they aren't helpful for you) if you have cable TV, satellite TV, or FIOS.
If you use an indoor or outdoor TV antenna (not satellite dish), then yeah, you'd need a converter for this model TV.
By the way, that is model DS25390, right? You left off the prefix.
Posted on Mar 03, 2008
"This is an analog tv and would need a converter box."
I just received this message from support@sanyo.com when I asked the question about my same TV and whether I would need a converter box when the changeover to only digital broadcasting comes (in the US) in February 2009.  So you  can believe the research I did or you can ask them yourself in an email.  Do Not Believe the flippant answer that was previously given.
Posted on Feb 25, 2008
    Problem Solver:
  • 9 Answers
Yes,,,ur TV is a digital one...
Posted on Jan 29, 2008
I need help setting the alarm on my vintage Sanyo Model RM 5005 radio
I just brought the same one at a garage sale, after a bit of fiddling around, i figured it out
To set the time:
1. Hold down the 'real' button
2. While holding it down, push down hour until you have the desired hour (if you want pm, you need to go around until the 'pm light' is on
3. While still holding down the real button, push the minute button until desired number is reached
To set the alarm:
1. Hold down the alarm button
2. Follow steps 2 and 3 of setting the time, except with the alarm button held down instead of the real button
Jan 30, 2015 | Sanyo Audio Players & Recorders
Sanyo 25" 10yr 25390 model
a loose connection may have caused this,try inspecting connections on audio circuits
Jul 13, 2011 | Sanyo DS25390 TV
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
What standard wrench replaces a 25 mm wrench
That is just under 1 inch. 25 mm is 0.98 inches. 25.4 is 1 inch.
I'd use a 1 inch and hope it isn't too tight. If you had some real rare wrenches like a 63/64th that is very close.
May 05, 2010 | Hand Tools
I have red lines going across tv. wavy lines also
This sounds like a convergence problem.
If model number is AV48WP30 go into the customer menu and select CONVERGENCE---if Red or Blue will not move in some direction one or both of the two STK-392-110 CHIPS this set uses for convergence is bad.
What happens is the convergence chips are black in color--about 2 1/2 inches wide X 1 1/2 inches tall with 18 pins each----the back of each is metal--when they are installed(each is mounted to a metal heatsink to keep it cool) they apply a white grease to transfer heat quickly----
After some years the grease dries out and one of the chips overheats and fails.
Not a real hard repair to do if you are handy and know how to solder----
Most shops are going to charge about 300 or more for this repair-----considering you can buy all the parts for under 25 dollars if you or someone you know can do it you can save a lot of money.
I can give you general instructions for this repair on this set.
I have repaired hundreds of sets with convergence troubles--very common problem.
Let me know if you have questions or need advice.
Regards, SD TECH
Oct 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Lens error 22 or 25
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 29, 2009 | Sanyo VPC-E760 Digital Camera
Sanyo
I did some lookin and from what i have seen, you are going to need a converter box for February. now two bits of good news. if you go to the fcc web site you can get cupons that make the converterbox about 25- 35 bucks. almost 75% off. now the next bit of good news. i found a manual for your tv.. just copy and paste the link at the bottom of this fix and it takes you to the page. there are tools on the side of the window to zoom move around and quick links as well. hope this helps
http://www.retrevo.com/support/Sanyo-DS25520-TVs-manual/id/17567dj489/t/2/
Jan 14, 2009 | Apex Digital AT2002S 20" TV
Ds 25390 tv
I think you will need a modulator with a/v in and channel 3/4 out
Dec 25, 2007 | Sanyo DS25390 TV
Sanyo 25" tv
blue clock set screen. is seen due to no signal as due to Accidently hit remote might have got defective or setting must have disturbed. refer owner's manual which you must have received during buying set. good luck
Sep 23, 2007 | Sanyo AVM-3659S 36" TV
TV SANYO MODEL DS 25390
It would be a waste to take this TV to Brazil, as this is not a Multi system TV, and will not recieve PAL M broadcasts.
May 29, 2007 | Sanyo DS25390 TV
Televison & Video Logo
108 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
