Question about Tapwave Zodiac2 Handheld
Tapwave zodiac 2
It keeps saying critical failure reset by hitiing the reset button on the back but nothings hapeening just the same message now that suck ause i need this thing for my fasgate 3 sixty.2
Re: tapwave zodiac 2
Remove any SD cards and check to make sure no buttons are stuck. Then do a function reset. This prevents system extensions from loading (you will need a soft reset after that to get back to normal operating mode). If that doesn't help, do a hard reset (this will wipe your data and you will need to restore it). If the problem comes back after you restore your data, you will need to hard reset again and restore your apps singly or a few at a time, until you locate which one is causing the problem. Or it may come back when you put your SD cards back in, in which case you may have one or more corrupted files there.
Posted on Apr 03, 2008
0 characters
3 Points
I have a demo version Zodiac Z2. I heard there's a "reversion program" to activate it. I want to know how to get that software.
I tried to find it anywhere online, however I can't find one. You may want to contact your manufacturer for sure they can provide you if there's new software for it.
Aug 05, 2011 | Tapwave Zodiac2 Handheld
The light wont come on!
Use the stylus to lightly press and hold the RESET button on
the left side of your device. The device restarts and displays the
Today screen.
09def71.jpg Warning! Always turn off your device before performing a soft reset or
installing/replacing the battery and SIM card.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset.
Jul 01, 2008 | HTC Qtek 9100 Smartphone
Bluetooth prob
Last I checked, Zodiacs are not phones, but are able to connect to a bluetooth enabled phone. Google a chord for it, Google is always your friend.
Feb 05, 2010 | Tapwave Zodiac2 Handheld
My screen for my zodiac tapwave 1 has a brown blob on it, like it was crushed. Is there an easy fix it for this?
Sounds like the LCD is broken. Tapwave has been out of business for a while now, so replacement parts aren't readily available; however, if you go on ebay and look for "Tapwave Zodiac Demo" you may find a demo unit. You can take the LCD off of this unit and replace your broken one.
Here is one listing
Hope this helps,
Sep 22, 2009 | Tapwave PDAs
System not working
just hard reset ur device
press both call and end key at once and then press power button at the upside of PDA for like 5 sec u will b egiven a menu to reset remove the card and reset the device then see if it helps
Feb 03, 2009 | HTC Touch Diamond Smartphone
New to htc
The half-white screen is definitely not a good sign. The "hold and tap" screen you see is the alignment screen normally seen at a "fresh" startup.
If this is the PPC6800 Mogul, there is a small pinhole reset button on the bottom of the unit. Using the stylus, push the button, This will "soft reset" the unit.
If this doesn't work, you can try hard resetting it:
1. Press and hold both softkeys on the device. (The soft keys are the buttons to the left and right of the center navigation wheel with the white dots on them) Keep these keys pressed, and at the same time, use the stylus to lightly press and hold the RESET button on the bottom of your device.
2. Release the stylus but keep the softkeys pressed when you see the following message on your device screen:
“Do you want to erase all user data and restore to manufacture default?”
3. Slide open the keyboard, and press R to restore to factory default or press X to exit the hard reset process.
This may take a few tries, as it's hard to hold the buttons and push the reset button.
Jun 11, 2008 | HTC TyTN Smartphone
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the
same time, use the stylus to press the RESET button at the lower left
2. Release the stylus, but continue pressing the two soft key buttons.
Release them only when you see the following message on your
device screen:
“Press Send to restore manufacturer default, or press other keys to
3. Press send on your device.
Jun 01, 2008 | O2 Xda Orbit Smartphone
Tapwave2 backlight out
If the backlight went at the same time as you replaced the battery, check to make sure you didn't damage or loosen any cables in there.
Feb 19, 2008 | Tapwave Zodiac2 Handheld
Unable to shut my z22 down
Having exact same problem. 2 options to turn it off 1.) reset button on back and 2.) hard reset - hold on/off button while resetting on back. Keep on/off button held in until Palm Powered screen appears. After that all programs are erased and you have to start over. However, I cannot figure out how to fix the data storage space problem.
Feb 01, 2008 | Palm Z22 Handheld
Hard reset
1 Hold down the power (on/off) button on your device. 2 While holding down the power button, turn over your device so that you can see the back of it. Still holding the power button, use an unfolded paper clip or a similar small object, to gently press the RESET hole on the back. 3 When the Palm Computing Platform or Palm Powered logo appears, release the power button. 4 A message will appear warning that you are about to erase all the data stored on your handheld.
Sep 15, 2005 | Palm LifeDrive Handheld
Tapwave Zodiac2 Handheld Logo
188 people viewed this question
Top Tapwave PDAs Experts
Are you a Tapwave PDA Expert? Answer questions, earn points and help others
