Question about HP Photosmart 2610 All-In-One InkJet Printer
Unable to receive fax unless Westell modem is disconnected
In the past I was able to receive faxes with modem on, now suddenly I need to turn the modem off to receive a fax. I don't have the Westell 6100 software manual to see if is set to receive faxes automatically,and from info I have from hp fax wizard, if it is turned on it prevents all-in-one from receiving fax calls. I also have Verizon DSL.
I'm confused. Please help!
Dolly McMullan
    Problem Solver:
  • 7 Answers
Sounds like you have a modem problem and that should the telephone company's call.
Posted on Feb 09, 2008
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
I accidentally disconnect the filter where does it go, on the westell? I have two phone lines one for internet and other for fax with a splitter
The filter should go into the wall jack, and the dsl modem should go into the "DSL" port of the filter, and the fax should go into the "Phone" port of the filter.
Also make sure that all other telephones in the house are connected to filters :)
Jul 15, 2009 | Computers & Internet
Unable to send and receive faxes
You need fax software or enable XP fax services. XP Fax services is enabled through the add/remove programs in the control panel. Open add/remove programs, and click on add windows services
Apr 15, 2009 | Arris Touchstone 450a (CM450) Modem
Unable to fax or receive faxes
Make sure the phone cord is hooked to the LINE OR FAX port.
Feb 16, 2009 | HP LaserJet 3055 All-In-One Printer
I have my fax machine hooked up through a magic jack. how do i change fax speed?
I contacted the folks at MagicJack today and for faxes they confirm your findings. They suggest the following: We do not officially support using faxing with MagicJack. Please try the following steps to use MagicJack with your fax (contact your fax vendor for details):
- turn off error correction on your fax machine or program
- set the fax machine or program to use the slowest speed available
- increase the speed, checking at each speed that faxes work
The change must come through your fax machine, not the MJ.
HERE is a link to the manual for your fax machine.
If you are having problems sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the Equalization for compatibility to
reduce the modem speed for fax operations.
a Press Menu, 2, 0, 2.
b Press a or b to choose Normal (or
Basic).
�� Basic reduces the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
�� Normal sets the modem speed at
14400 bps. (Default)
Press OK.
c Press Stop/Exit.
Note
When you change the compatibility to
Basic, the ECM feature is only available
for color fax sending.
There are only 2 speed settings. Since the MJ does not support faxing, if the slower 9600 bps does not work, you will be unable to fax with the MJ.
Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | Brother Multi-Function Center MFC-240C...
My lexmark x2500 fax can't connect to my modem, but recognizes it exsists!
I have a lexmark x4270 all in one that I need help connecting to my westell 327 modem and phone line PLEASE HELP!
Sep 29, 2008 | Lexmark X2500 All-In-One Printer
Re initializing a data/Voice Modem
Go to start,control panel,hardware device and see if your moderm is still there. If so, right click on top of the moderm uninstalled. Turn the computer off and back on. At this time, it should come back on and look for the modem.Answer yes to found new modem and reinstall the modem. this should work
please check you modem setting. it could be that your setting also is not correct.good luck
john
May 27, 2008 | Computers & Internet
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
