Question about Acer Aspire 3000 Notebook
ACER ASPIRE 3002WLCI
I HAVE BOUGHT A BELKIN UNIVERSAL ADAPTER, AN IGO UNIVERSAL ADAPTER AND A BRAND NEW BATTERY ALL SEEM TO WORK INITIALLY THEN LAST NIGHT THE CORDS STOPPED WORKING AND RAN MY BATTERY CRITICAL. i PURCHASED ANOTHER BEKIN UNIVERSAL TODAY AND IT TURNED GREEN MOMENTARILY RAN THROUUGH THE SYSTEM CHECK AND SHUT DOWN UNEXPECTEDLY BEFORE I COULD SEE IF IT WAS ACTUALLY CHARGING... i HAVE REMOVED THE BATTERY AND TRIED STRICTLY AC POWER TO NO AVAIL... ANY SUGGESTIONS?
  • asokar_mail Aug 15, 2008
    My laptop is Acer Aspire 3000
    My laptop problem is Video graphics is not support, so I want Graphics control driver files.
    Pl...help me....
  • 145 Answers
Probably a voltage regulator, they are usually available on ebay, but I suggest having it done at a repair centre.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Acer Aspire 5532 battery replacement charged initially, now says it's charging but stays at 0%
If these were both batteries bought online, say eBay... you may have been shipped defective product.
If not, it sounds like the charging mechanism within the laptop is no longer re-charging your batteries. This will require a visit to your local computer repair shop most likely.
Nov 10, 2017 | Acer Aspire 5241 5251 5332 5334 5338 5516...
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
Laptop will only charge when switched off
get orignal charger for acer aspire 5735 pc and then try again
May 03, 2010 | Acer Aspire 5735 Notebook
Need a new adapter for my 620 laptop.. immediately. any ideas what I can purchase to get me going tomorrow?
I'm not sure exactly what "620" laptop you have, and exactly what "adapter" you're looking for, so I'll assume it's a power adapter. If it's one of the major manufacturers like Dell, Acer, HP, Gateway, etc... you should be able to find a universal power adapter from places like Best Buy or Radio Shack. I know they both normally carry a universal power supply for laptops. It's auto-voltage-sensing and comes with a bag of inter-changeable power connectors to fit most laptop models. I've seen these made by Belkin, iGo (Radio Shack), and Targus.
Jan 14, 2010 | Televison & Video
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 3680 JUST QUIT WORKING-NO POWER-HELP!
Pull and reseat, Memory, Battery and hard drive
Jul 04, 2008 | Acer Aspire 3680 Laptop
Acer 5570Z......... Battery Reported as UNKNOWN!!!
To break in a battery for Acer, you have to charge it up, then let it run down completely 3 times! The battery only has a 300 recharge life, so you must never leave it in your Acer when you are plugged in. Use it only when you need a battery, then take it out. Be sure to use it set for battery use, with minimum drain. only recharge it after it is exhausted. It sounds to me as if you bought a bum battery.. Call them, and ask for a replacement.
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Touch pad and keyboard freeze after startup
Battery problem, remove battery... fixed!
Feb 19, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 5100 Red Battery Light
The Aspires should have no issue booting without the battery installed. Have you done a static reset? (i.e. hold the power switch for 20/30 seconds without power or battery in) And the voltage range on the Aspire 5100 should be +19v - +20.5v on the inner part of the connector so it might be worth checking that the power adapter is outputing correctly.
If it works without battery, then it can be checked by testing the voltage between pins 1 and 6 on the battery (the ones either end) and should be 7.5v or above if the battery is charging correctly.
Hope that gives you a starting point, if you've done all those things already then appologies and best of luck with it.
Dec 10, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 3000 Notebook Logo
161 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
