Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Weak pick up power
Using my vaccum i dont know if i picked up a metal hair clip in the rug,i heard it going through the machine,then i noticed when im vaccuming it wasnt as strong as it was before that happen.
    Champion:
  • 207 Answers
That's true!!! you've take that for granted because metal strips such as the hair clip will tend to deteriorate the engine power. Since the turbine of your vaccum cleaner uses dynamo to provide for spin and it has supply electromagnetic charge. Since there's a metal that has picked up, it will absorb the magnetic power of dynamo causing your engine to malfunctioned step by step.. Better check the engine to a liscensed technician to repair the problem.
Posted on Jan 28, 2008
Why won't my shark navigator cordless vacuum pick anything up?
Sometimes everything seems to be fine. The brushes turn, but if the brushes aren't cleaned of hair, rug tangles and so on, the brushes on the vaccum get filled and it won't puck up anything. ON THE OTHER HAND if the brushes are clean, did you check all your hoses from thr base of of vaccum where things get sucked up to the bin?
Jan 27, 2016 | Shark Vacuums
Can you use a carpet freshener before vaccuming?
it can be done though the level of filter cleaning to finish the job might be a lot more than you expect
use a mask.
Dec 02, 2014 | Vacuums
It is a dirt devil Royal which I use to vaccum stair steps. it is a new vaccum . not it will not work, the brush will not rotate. I looked to see if some hair was the problem but no hair or fuss. ...
Hi, I am sorry it took this long to get back to you and I promise I will get right on this. We are having issues with our e mail notifications.
You say this is a new vacuum, do you mean brand new? never used before? I am going to look into the dirt devil problems and see if we can narrow down the causes. I assume you tried this in several outlets to make sure it is not the outlet. Does the motor run at all? or is it running but the brush not turning and not picking up dirt.?
Nov 07, 2011 | Vacuums
While using the power mate rug part I caught a small rug and the vacuum would no longer pick-up .
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
Noisy on rugs!
Are the rugs long haired or short haired? Most likely the suction is just causing the noise when it picks up the rug and the buzz saw could be the beater bar hitting the rug then. I actually own a DC14 and it does the same thing and the rugs like to be dragged along. Nothing really to fix this, just the way it is. You could try it with the beater bar raised and see how well it works then but this sounds normal.
Have a good day
bestdarngood
Feb 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson o7 animal pick up problems
Hi.
If your machine is A few years old it may need new brush roller fitted.
To check roller for wear lie machine on the floor & pull back head end as if vaccuming carpet.
Now get A rule or straight edge hold this over brush roller & sole plate oppening.
Now rotate brush slowly by hand the bristles of the brush should just kiss the edge of rule. If ther is a gap you will need toreplace the roller.
http://dysonmanuals.llc.nu/
Jan 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
