Hey need to ask
I want to know how to fix your printer it want print for some odd reson it says problem comutacaton with the printer can you help me
    Scholar:
  • 103 Answers
First off, more info is needed, like name and model # of printer. But, here is something to try. Re-boot the computer with the printer disconnected from it. After booting up, re-connect and try again. It may be necessary to uninstall and re-install the software for the printer to get things straightened out.
Hope this helps, and if so, please rate my advice.
Posted on Feb 05, 2008
All I want to do is to be able to print off the whole manual for my 'Epsom DX3800 All-in-one printer'. I have already contacted Epsom several times concerning this and have not receive the help that I...
if you want print both side you need duplex printer. but you can print from normal printer also. for this you have to select odd option in printer window then print. by this way printer will print odd page numbers 1,3,5,7... only. after that flip printed pages and select even option in printer window. this will print even page numbers 2,4,6,7... by this way you can print papers both sides.
Mar 12, 2011 | Epson Office Equipment & Supplies
Paper mismatch error
I got around this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Green tint when printing
Hi, did you tried to calibrate your colors but on the printer? The printer decides which color it's gonna print, regardless to the color on the screen. He's gonna try most of the time to print the closest color he can make. We call this WYSINWYG. What You See Is Not What You Get. You should have a tool with the HP printing software. Otherwise i guess you can print a test page to check the colors. Make sure each color Cyan/magenta/yellow and black print corectly on the test page. Usally on HP printers you have to hold the Go button 5-10 sec and it's gonna print the test page but refer to your manual if you are not sure how to do this. Could also be a problem with your print heads, check if there is a procedure in the manual to clean those.
Jun 05, 2009 | HP PhotoSmart 7760 InkJet Printer
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing Envelopes
There is a workaround for this problem by tricking the printer.
Deny
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart C7280 still prints in color
Why don't you try changing the Setup for your printing to Black & White or Grayscale in your computer's software: File/Print/go to the printer's settings and disable anything color. As for the cartridge, it's probably the cartridge. If you have an extra, why not swap it out? I believe the brains in the cartridge contacts might not be working properly OR your heads need to be cleaned OR you better stick with HP original cartridge to make sure it's not the printer. I used to use "odd" ink and even refilled ones and shortly thereafter my old printers would die. Not taking a chance on this HP. I love how it prints when it isn't jamming the paper! Need help on that problem pronto.
Jan 06, 2009 | HP Photosmart C7280 Laser Printer
MPC400 BJ-10e 'ready' but not printing.
Hi there
Cause: Error 12031 takes place when the system is misconfigured or it's essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 12031 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
Download Error 12031 Repair Tool
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 19, 2008 | Canon SmartBase MPC400 All-In-One InkJet...
How do i print on both sides of the paper
I still do not know how to print on both sides of the paper. I already paid US $200.00 for the printer do you think I should pay more to get what I though would be a simple problem solved? I don't think so!! That's my solution!!
Nov 06, 2008 | Brother Multi-Function Center MFC-240C...
37 people viewed this question
k24674
jasbo
jasbo
