Question about ION Audio iTTUSB Turntable
Ion ittusb turntable drive belt
I followed the instructions to set up this turntable. However, the drive belt was preinstalled around the inner bottom ring of the turntable platter. When I got ready to pull the rubber drive belt off of the inner ring and intall it over the motor spindle, I couldn't because the rubber drive belt is stuck in the bottom of the turntable platter. I called Ion, but was unsuccessful in solving problem. Does anyone have a suggestion, otherwise, I am going to send this flawed turntable back, because I think that the drive belt wasn't properly installed!!!!!!!!!!!!!!
Thanks!
Jeanne
  • 515 Answers
If the belt is stuck, it will be hard to take off without damaging the belt. Send it back.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
Denondn hs5500 to traktor
Hi Jeib,
Here you go. Check out this review and search engine.
Ion Ion Audio Ittusb Turntable Reviews Ion Ion Audio Ittusb Turntable...
Here is the direct review from a variety of You tube sources with your product in their hands. Take a look.
Denondn Hs5500 To Traktor Reviews Denondn Hs5500 To Traktor Product...
Since your question is generalized. I still wanted to share this forum www.product.info is the place to go become a member and join in the forum. Go for it.
Fare. Well.
May 17, 2014 | ION Audio iTTUSB Turntable
Drive belt bare hands
Won't usually hurt them, but it's nice to have a non-slipping belt. Just clean it up with a little rubbing alcohol.
Mar 02, 2014 | ION Audio iTTUSB Turntable
My stylus is broken can it be fixed if so can I put a new one on. how is this done please
Google "iTTUSB Turntable stylus" and shop around. It just slides off the cartridge body.
Apr 23, 2011 | ION Audio iTTUSB Turntable
The turntable will not spin the record or at all.
Most likely the drive belt has come off or is stretched beyond being usable. we stock belts for all model turntables. styluscity@gmail.com
Sep 05, 2010 | ION Audio iTTUSB Turntable
Bought an ion turntable (contour lp) and after playing a few records it just stopped mid way through playing a record and wont work anymore. its not the fuse. have you any idea what it could be??
If the turntable is a belt driven unit have you checked to see if the belt has slipped off from around the inside on the platter. Or maybe it could be snapped.
Put you ear to the turntable and switch it to play (you will have to pull the tone arm to where it would normally be to play an LP) listen for a faint noise of a motor running. If you can hear it, the drive belt could be the culprit.
I just checked and YES it is a belt drive. I'll bet my boots that's the problem. Pull the power plug and inspect the actual platter to see if it's removeable. You may have to rmove a circlip from the main drive shaft to remove the platter. To replace the belt. Slip it over the motor shaft and lay it in the bottom under where the platter sits. Then replace the plater and using two fingers pick up the belt and guide it onto the rim the inner rim under the platter and keep rotating the platter slowly until the complete belt is around that inner rim.
Things are now ready to go. If the belt continues to fall off it means it''s been stretched and you will require a replacement. Obviously for free if it's under warranty. Changing the belt yourself shouldn't void the warranty.
Apr 24, 2010 | ION Audio iTTUSB Turntable
ION iTTUSB turntable has buzzing sound when I record
It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
Nov 28, 2009 | ION Audio iTTUSB Turntable
Ion turntable install disc is in Japanese only
The Ion page for this turntable is here. Maybe you'll find what you need there. Where did your unit come from that it has only Japanese-language instructions?
Apr 25, 2009 | ION Audio iTTUSB Turntable
Turntable does not turn round
Have you put the drivebelt around the motor spindle - the instructions don't make it too clear. The belt is already on the underside of the turntable, you just need to put a finger through the hole in the turntable, pull the belt out and hook it over the motor spindle. After that, if you've pressed the power button (back right), you should see the 33rpm light come on. If it's on, press either of the 2 big buttons on the left hand side and the motor should turn. You can check by looking through the hole in the turntable & see if the motor spindle is turning. If none of the above work then you have a faulty unit.
Jan 01, 2009 | ION Audio iTTUSB Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
It doesn't work!
with everything plugged and running go to preferences in FILE and set Recording Device and channels to Audio device USB in Audio I/O.Tick software playthrough.
now set the microphone box to Stereo mix on the home screen(box is left of small scissors) hope this helps.nigel.
Dec 26, 2007 | ION Audio iTTUSB Turntable
ION Audio iTTUSB Turntable Logo
430 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
