Computers & Internet Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had a 1 gb ram on the my Asus P5VD2-MX mother board and tried adding 2 gb to the 2nd slot but computer alarm sounds. I swapped the 1 gb to the 2nd slot and alarm sounded again?? It seems the 2nd slot will not take any ram?
Florin
Level 3:
  • Master 733 Answers
  • Posted on Dec 29, 2009
Florin
Master
Level 3:
Answers
733
Questions
0
Helped
166450
Points
1640
 you put the 2 gb in the first slot(that's the default setting on all motherboards-the biggest memory is in front) then in the second slot the 1 gb after that restart if you get the same sound the remove the battery on the motherboard and put it back to reset the bios after that restart.
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
3answers
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to [email protected] .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
1helpful
My Mother Board is ASUS P4GE-MX. How much GB does the RAM spport.
ASUS P4GE-MX Motherboard has two RAM slots Supporting DDR-I, 1GB each. Hence, it supports 2GB RAM Max
Click here for more details (if required)
Dont forget to rate the solution if I could have been of any help!
CreativeTECH
Not beep
NO beep its depends on the condition.
with out RAM it means mother board foulty...
with RAM no beep sound it means replace the RAM. ok if Same problem Accure means mother Foulty.
2answers
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
2answers
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Wayne
ASUS P5VD2-MX SE
ไม่มีเสียง
38helpful
2answers
ASUS P5VD2-MX SE sound driver
you can download the audio driver for your motherboard from some of the sites given below ...
http://www.nodevice.com/driver/P5VD2-MX/get34077.html
http://www.nodevice.com/driver/company/ASUS/Motherboard.html
http://www.driverstock.com/ASUS-P5VD2-MX-driver-download/6-9-10181/index.html
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
2 gig ram stick
Absolutely, 2 Gigs stick of RAM exist. Unfortunately your motherboard's maximum memory supported is 2GB. This site specifies very clearly 1 gig stick max per slot:
http://www.crucial.com/store/listparts.aspx?model=P5VD2-MX+SE
A.J.
Grand Canyon Tech
Grand Canyon Tech
