Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Cannot connect to wireless network
I have a linksys srx200 model and I am having trouble connecting to the network. I have a full signal and when it connects, there is limited or no connectivity. I have tried repairing the connection and have reset the router and modem several times. Any other suggestions?
  • 1 more comment
  • cry1rose Jan 30, 2008
    I have not tried that yet, but I will post a new comment when I am around the troubled router! Thank you!
  • olshie Sep 17, 2008
    I have the same problem but the DHCP is enabled and I am running cable internet.
    I have tried resetting the router, upgrading my firmware, repairing the connection ...
    I am starting to think my wireless router is no more?
  • Jon White
    Jon White May 11, 2010
    Are you able to get onto the router management page? typically at 192.168.1.1
    What do you use for internet, cable, or dsl?
    New Friend:
    Problem Solver:
  • 8 Answers
Most Cable ISP needs mac address mapping at their end before the connection starts working thru thr router. Obtain the Router's MAC address and pass it onto the Customer service folks of your Cable ISP. Once they map it to your account, the limited connectivity problem should disappear.
Posted on Jan 28, 2010
  • 38 Answers
I agree with JonwVBFL, it sounds like the DHCP server is not enabled on the router. You can enable this using the administrative web interface on the router (http://192.168.1.1). The default username is admin with a blank password or vice versa.
Posted on Feb 02, 2008
6ya staff
SOURCE:
I have a linksys wrt54GX2 wireless G router and I would like to use it as an access point to pick up our internet signal from downstairs. The modem in use is wireless motorola SBG900. I have a desktop and...
With that particular model you wont be able to use it as a wireless bridge. You can however run an ethernet cable from the modem to any point in your house. the SBG900 i believe has wireless built into it, so you may need up with 2 wireless networks.
Hope that helps.
Feb 05, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Im trying to get my xbox live nat type to open i have the linksys wrt54gx2 router with srx 200 please help my by giving instructions on fixing this problem.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Does it mean my adapter is bad if it just stays lite up green and doesn't flash to try & connect to the internet? I installed everything correctly but it still isn't working. Any ideas? I have a belkin...
The Linksys adapter should have a program you open to find and connect to your router. If not, you can use the Windows Network settings to find your router and connect. Although 54G is a slower speed, they should still connect.
Jan 28, 2018 | Linksys WRT54GX2 Wireless-G Broadband...
Another application is controlling the wireless adapter
I believe you are using WINDOWS XP.
In case of windows XP, there might be 2 different wireless utilities can control your wireless adapter.
First utility is the manufacturer's utility. If you have Dell wireless adapter then you can use Dell utility to connect to the network.
Another utility is Window's utility. You are getting the error message in this utility because your computer is using another utility.
To use window's utility you will need to start the " wireless zero configuration ".
Click Here
for more information about wireless connection
Feb 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
Aug 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Keep losing the signal. appears that the power
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 25, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Connecting linksys srx200
It means that the router is not yet configured properly for internet connection. Who is your internet service provider and what is the model or brand of your modem?
Aug 20, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
171 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
