Question about Canon PIXMA MP510 All-In-One InkJet Printer
Not regcognizing cartridges...
The Canon MP510 will not recognize, at all, the Magenta cartridge. Printer worked fine for 4 months without any problems but started randomly not recognizing Magenta. Now 100% will not print anything because of the unrecognizing issue. Help!
  • 2 more comments
  • Anonymous Feb 14, 2008
    i have this problem too but with the yellow, it's an offical cartridge & does fit.
    Does anyone know how to override it?
    thanks
  • Bezerk Feb 22, 2008
    Same problem but me its with the black cartage.
    Bought it this summer and barely used it now i cant do anything with it
  • Anonymous Feb 29, 2008
    The printer has only been used a few times. It started not recognizing the magenta cartridge but was fine once the cartridge was reseated, but I had to do this every time I wanted to print. Now it won't recognize the cartridge at all and I'm hooking up my old HP- at least it will print.
    My printer has only been used a few times. it began not recognizing the magenta cartridge but was fine if the cartridge was reseated. Now it won't recognize the magenta at all. I'm going back to my old HP- at least I can print with it.
  • 39 Answers
May not be the be the right size
Posted on Feb 09, 2008
A canon ink tank is not being recognizd. Previously it was working fine. Then I added a new black cartridge. Now the magenta won't work. All Canon cartridges. Trina
All ink tanks has a memory chip.With this chip the printer recognize the ink tanks and the ink level.Sometimes this chip failed.Just replace the magenta ink tank.
Nov 24, 2009 | Canon Pixma MP950 All-In-One InkJet...
Brand new magenta cartridge cannot be recognized U043
a brand new magenta cartridge cannot be recogined for a HP 3310 printer
Aug 02, 2009 | Canon Pixma MP800 All-In-One InkJet...
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Installed #8 M(magenta ink cartridge) New ink tank.
The problem can be one of the following:
  1. You have a faulty cartridge chip (return to purchaser and request a replacement)
  2. The chip is soiled (ink or similar is causing the connection to fail) so try cleaning the chip
  3. The chip is not properly mounted on the cartridge (maybe skewed slightly or similar). If so try straightening out carefully and then re-inserting.
Canon have been known to send out cartridges with bad chips so you should contact them if you bought a proper one and they'll sort you out.
Mar 09, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Cannot recognize ink cartridge
I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
Jul 22, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon Pixma MP610 CARTRIDGE PROBLEM
HI. Try holding the reset button for 6 seconds to overide the error. This may dissable the chip so it won't report but will allow you to keep printing. Simply check the ink tanks visually.
Refilling will give the same error too, again dissable the error.
Cheers Bob Monk (ink manufacturer magink@froggy.com.au)
Feb 29, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
I had the same problem. I was using original brand cartridges and it was still not working. Here's how I got it to work. I recommend doing each step and then trying to print a test page to see if it is working.
1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
3. From the same menu I also ran "Clean Print Cartridges"
4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Good luck. Hope this helps.
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Frequent problems with the magenta cartridge of my PIXMA MP510.
Dirty or faulty contacts in the cartridge chamber is the only logical explanation.
Remove the cart and with a cotton wool bud and a little alcohol or similar[NOT ACTETONE it melts plastic] give a gentle clean.
Oct 24, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
146 people viewed this question
old marine
old marine
