Question about Nikon D80 Digital Camera with 18-135mm Lens
F-- when i want to take a photo, the camera wont let me, and it keeps flashing f -- what does this mean and how can i solve the problem. Annabelle
  • 09mbann Jan 29, 2008
    i have thought of that, and i am using it on fully auto mode, however i still seem to be getting that message. and i have also ltried removing and reinstalling the lens. could there be any other solutions?
    ("devocap" - thanks for the words of wisdom, but i have spent rather alot of time reading the manual - was the first point of call)
    Problem Solver:
  • 9 Answers
EXPLANATION.
f-- meaning that the aperture is locked to smallest aparture. this is because the camera didnt receive aperture information from the lens, and the body cant send signal to lenses regarding the aperture value. The problem here is the contact point.This problem always happen to Plastic mount lens like the 18-135mm kits len. Somehow after long use the plastic mount had weaken a bit that enough to make the contact not really contacted....
SOLUTION.
Remove the lens. Try to clean the contact point at the lens. Then mount it back. It should be okay. if still happen, try thighting more, until the f-- disapear. If that wouldnt happen, then u should consider metal mounting lenses. hehe
CONCLUSION.
it is advised to buy metal mounting lens.
thanks....
DuKu
Posted on Nov 04, 2008
    Sergeant:
  • 201 Answers
Hey there 09mbann, the problem seems to be that you have the camera in Aperture priority setting, and is therfore looking for a setting which you have failed to give it. Try setting the camera to fully auto mode, ensuring both the body and lens are set to auto. This should allow you to take pictures, when focused. I would suggest you spend some time with the manual, in order to fully appreciate your camera and it's features. I hope it helps. Good Luck!
Posted on Jan 28, 2008
    President:
  • 423 Answers
Try removing and re-installing the lens. If that doesn't do it, give the lens a little extra twist in either direction. The contacts may not be lining up just right. If still no better, take the lens off the body and inspect the contacts at the top of the lens opening in the body, and also the contact points on the upper portion of the lens mounting flange. Gently clean with some alcohol and a cotton swab.
6ya staff
SOURCE:
Why can't I access my photos on my computer from sony memory stick pro duo 4GB but can view on camera?
You may be able to get the images from the card. try using a program called BadCopy Pro. I used it a few times to get back images from memory cards that would not work on any computer. Good Luck.
Jun 01, 2014 | Sony 4GB Memory Stick PRO Duo Memory Card
Canon prima flashing E
First reaction, when your camera acts strange, is to switch it off. Then when the memory access light stops burning, or flashing, you can remove the battery (Batteries) Give it a few seconds, and then reinsert the battery. Now the camera will start from scratch. So if the problem was caused by a software problem, it should be solved.
Only when after switching on, the error reoccurs, you have a bigger problem, that perhaps only can be solved in a photo store, or at the service centre, closest to you.
Jan 26, 2014 | Cameras
Dark pictures
Check Exposure compensation. If you have a negative number all photos can be dark with flash or no flash.
Nov 22, 2013 | Nikon Inc Nikon Coolpix S01 Silver
I have canon g1 3.3 i turn on and it flashes letters CF what does that mean
Strange problem this one. Could mean insert a Compactflash (CF) card or that the CF card is full of maybe even Custom Functions are set. A photo of the display would help me better to solve the problem.
Apr 09, 2013 | Canon PowerShot G1 Digital Camera 3.3MP
Green light on back of camera is flashing and I cannot view my photos
Green light flashing means that the camera is reading the memory card. If it keeps on flashing and flashing means that the camera is trying to read the card and not able to. This means that there is something wrong with the card. You should stick your card into the computer and transfer all your data from the card on to the computer. after all your photos are safe on your computer, put your card back in to the camera. turn the camera on, press the menu button, navigate to the menu that looks like a wrench and in that menu select "Format Memory Card" this will erase and format the card to how it should be. after that, you should be able to view your photos normally. If that doesn't work your card may be faulty and you may have to purchase another memory card.
Note: the camera might not display photos that you downloaded from you computer on to the card, cameras often only display photos that you took with the camera.
Feb 28, 2011 | Nikon D60 Digital Camera
Flash wont fire
my flash won't turn on at all either.
Mar 23, 2008 | Nikon Coolpix S51c Digital Camera
Error B8e7b69c
I have had this issue happen to me when trying to print a photo from my windows picture program and from the window photo gallery program on Vista. I believe the problem is a compatibility issue with the windows Vista photo programs. I was able to print very well using another photo program. So i suggest printing from another photo program. My camera came with one that is pretty basic and good at fine tuning the pictures. I used the Canon zoombrower ex program and it printed all my pictures well. I think most digital cameras come with some type of photo editing program. You should try printing from it instead widows photo folders or windows photo gallery. Using my camera's photo software solved my issue well. try this out to see if it works for you. good luck
Mar 20, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
About the spots on photos..
I recommend returning it. Nikon's QC may be lacking these days
Feb 03, 2008 | Nikon D40x Digital Camera
Red eyes
As both the camera and the flash does not have red eye reduction facility, you can solve the problem by not using high speed film, i.e. not more then 100 ASA and avoid shooting in very low light.
Oct 30, 2006 | Vivitar 2800 Flash
Nikon D80 Digital Camera with 18-135mm Lens Logo
74 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
