Question about Marantz PM-68 Amplifier
Marantz 2240 I disconnected and re connected my beloved 1970 classic tuner and lost all the control knob functions; volume, fm,am, bass, balance you name it. Wuold it be a simple fix or did I blow something major out? Where could I get a part if it is one part only. It still works but the volume is on blow out level. It works on the setting I last had it at. Thanks Susan
  • 1,512 Answers
Hi there, be sure that you have reconnected the jumpers from pre am out to power amp inm opn the rear of the unit. You will get very little of anything if you leave these jumpers out. Also check that you have not inadvertantly turned on the taoe monitor. Give the switch a few operations to check that it isnrt playing up also.
If you are still having problems, feel free to get back to me here and we can sort this out for you.
regards
Graeme
Posted on Mar 17, 2008
Coby cd troubleshooting
Coby outta business - bankruptcy. Cannot get parts so ..............
Jul 31, 2016 | Coby CX-CD377BLK Micro CD Player Stereo...
There is a crackle when i turn the volume knob.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
Jan 09, 2014 | Marantz Vintage Model 2220b Stereophonic...
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Is there a balance control on this radio or is that fixed???
Hello kayriecken,
You did not specify whether you have the old classic Becker or the new retro. I'm pretty sure that the knobs were "spring loaded" on my old '60's Becker (actually in a 1971 Mercedes 280S - later replaced with a Blaupunkt). On mine, you just pulled out lightly on the knob and it switched function to balance. One side, the volume controlled left to right balance, and the other side, tuning, controlled front to rear balance (fader). Try it and see if it works.
Hope this helps.
May 04, 2009 | Car Audio & Video
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
No Sound
go to standby hold m-log button tell menu comes on display press up on volume control tell amplifier comes on display pess left on volume control tell display says amp on. the built in amp on the stereo turns of and on to provide better sound quality to the pre-amp out puts
Oct 03, 2008 | Kenwood KDC-X590 CD Player
Volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Jun 21, 2008 | Marantz SR-5200 Receiver
Fade and balance
Bass, treble, balance and fader are all accessed by pressing in on the volume control knob. Press and release repeatedly to select the various functions, then turn the knob to make adjustments. An owner's manual can be found here: http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13668&langId=-1
Jun 10, 2007 | Jensen CD4610 CD Player
Marantz PM-68 Amplifier Logo
246 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
