Question about LG Televison & Video
LG RE44SZ21RD - Ballast problem???
Today when my girlfriend came home and turned on our tv (LG RE44SZ21RD) she also turned on the AV amp. I think by misfortune they both tried to kick in at exactly the same time and drew too much current for our RCD throwing the trip switch.
I switched the TV to off, then reset the trip switch, then turned the TV back on. The tv came into standby fine (red LED illuminated as usual) and when I used the remote to turn the TV on that seemed to work too... The green LED flashed several times then stayed on. However, I get no picture.
Let me stress: The TV does not turn itself off after a certain time or give a flashing amber LED - ie protection circuit is not activated (so as far as the TV is concerned everything is fine).
The problem is that the lamp is not illuminated at all. I decided to check if the lamp had blown by replacing it with one I know works. (I replaced my old lamp when it got to 6k hours despite the fact it still worked - so I used this for a test).
So I guess the next most likely fault is the ballast board. The one in the TV is an OSRAM board - 3757790027. LG part number 6316000002D.
What I want to ask you guys is... is the ballast likely to be the problem? what is the procedure to test the ballast board?
I am a physics phd student so I have some electronics knowledge and have some lab equipment available to me.
SOURCE: Turns ON than right back OFF!
Yup, same problem here.
Posted on Feb 28, 2008
Slinteriors
  • 8617 Answers
SOURCE: ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
Posted on May 12, 2008
  • 98 Answers
SOURCE: Mitsubishi WD-52525 Lamp ballast
Contact Mitsubishi Parts themselves, 18005537278. They are very friendly.
Posted on May 15, 2008
SOURCE: Need to buy a lamp & Ballast
http://electrified.com/Catalog/Items/?CampaignID=Froogle&ItemID=35508
Posted on Dec 20, 2008
SOURCE: Cant find a ballast
The ballast is actually a switch mode power supply that powers the lamp. It is an
integral part of the light engine and is not replaceable. The light engine has a price
tag of $950. If you replaced the lamp with an after market one and not the Toshiba
lamp you can experience the same problem. Some of the after market lamps will
not fire at the same voltage as the Toshiba. The blue led will come on solid and the
yellow blinking. It will try to start 8 times then give up.
Charlie
Posted on Dec 31, 2008
I have a lg 42"lcd tv turn the volume up and it just goes all the way up to full volume byitself same when you lower the volume.tried adjusting volume from side of tv manualy same thing.
What might be happening is that you have connected the TV to a home theater AV unit. I have a similar set up and as long as I am running the signal from my computer to the AV system, audio control is via the windows application and the AV system. The TV has no audio control. This can be especially true if you are connecting the TV directly to a computer.
Apr 12, 2015 | LG Televison & Video
How I can connect my Samsung Home Theatre System ( 7-1 channels AV receiver) using the HDMI V 1.4 3D cables to connect them to to my LG 55 LX 9500 3D HDTV LED TV . The equipments are :( LG Blu Ray...
ideally you would simply add an hdmi source from each device to the surround receiver and send the output to the tv but im thinking your amp may be short on inputs from all devices and if indeed it was this simple you wouldnt be here seeking this info also note you may be able to use the output on the set to gain another signal tranfer but note there can be compatability issues on some sets whether they will decode hdmi in and rca out or optical out like i said some sets ok :) i wish you luck and wishin i had this all in front of me so i could be a greater help any q's drop me a comment here ok :)
Feb 26, 2011 | LG Televison & Video
I can't get my freeview box (Philips DTR 2010 to work. Had it working in my flat earlier today & have brought it home for wkend where it's wrkd before. All plugged in but the TV stays 'snowy' when I...
Select the AV input manually via the TV remote. The scart lead may not be switching the TV automatically (if you have two scarts on the Freeview box, then try the other scart socket).
Feb 18, 2011 | Televison & Video
Ballast 6913v00002c is a different size than the original
The old and the new parts have same model's of tv and same parts #---.All way fit,if the parts of the tv is one of the main componnents that make the tv work.Talk to ur ventor u buy it from yet?Explain the problems,work somethings out.
Mar 29, 2010 | LG RU52SZ30 52" Television
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
Re44sz21rd
HI,
All I can suggest is to replace the bulb. I experienced a similar problem after about 2 years viewing when the recommend lamp life was approx 8000 hours (I got to approx 3000 hours). There is a service menu you can access where you can reset the lamp hours time. I have read that if this is reached you must replace your lamp, but you can extended this by reseting the hours.
I have since learnt that a lamp bulb can go at anytime, so it is worth having a spare. Also I have noticed that switching the TV off at the switch (not leaving it in standby helps).
Try this to access the service menu. Holding down the menu button on the remote and the one on the TV for a few seconds. I think the TV needs to be off.
From memory, I think it is option 4 and option 5, then reset the lamp hours to zero
Sep 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Need new ballast, I think... Where do I get one?
You can purchase the service manual for your model at the following link and they will provide free tech support to help you diagnose and locate any parts that you may require. they email the service manual almost instantly after putchase. heres the link look under the LG section for your manual.
May 05, 2008 | LG RU-44SZ61 44" Rear Projection...
DLP TV Blown Bulb: LG RE44SZ21RD
what kind of tv do you have I need that info so I can help you
Apr 10, 2008 | Televison & Video
Lg with a mind of its own
My REsz21rd is doing the same thing, switching off after a short time and then struggling to re-start. The LG repairers say it's the projection engine and have quoted £2000 for a new one. What a joke!
Apr 02, 2008 | LG Televison & Video
Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 27, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
119 people viewed this question
Computer Repairing
Computer Repairing
