Question about Uniden TRU8885-3HS Digital Cordless Phone
Uniden phone 5.8ghz
How do I get my phone to read with caller i.d. again- it just stopped working and reads "incoming call"...
  • 1 more comment
  • damodar rao Apr 04, 2008
    caller I.D. number not showing when incoming call comes to my phone. I have provided with caller i.d. facility with the service provider.
  • ptldeborah Nov 20, 2008
    I unplugged the phone for awhile, and when I plugged it back in, the caller id was not working. I cannot get it to work.
  • Kschiess Apr 30, 2009
    Caller ID no longer works. It works fine on another uniden base I have. Is there a circuit problem with this model?
  • 65 Answers
Make sure that you have caller id service from your phone company. If you do not have a different phone with caller id borrow a working one from a friend and see if it shows up on a different phone. Let a phone ring at least twice to give caller id time to work. If a different phone does not show the call information call your service provider.
Posted on Jan 28, 2008
My Uniden Dect handset has stopped working. No dialtone. Also message on handset reads:'New CID:50'
CID(caller identification) your phone logs incoming calls in it's memory. The #30 signifies that there are 30 CID(phone #'s) logged in the memory of phone from callers. The phone saves the information for the last 50 received calls to the CID list. The NEW icon marks any calls received since the last time you checked the list. You can delete these one by one or all by pressing ID (CID# will come up) then press menu/select button I believe 3x and repeat until all unwanted CID's are deleted. page 9-10 of the Dect 6.0 manual below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button. https://www.101phones.com/content/pdf/un...
So your problem isn't related to that message. Disconnect your unit from the wall plug. Remove the handset battery, count to 10 and put it back. Plug the base unit in and try again. You need to check the line jack with a standard phone to make sure the line is good.
https://www.101phones.com/content/pdf/uniden/D1760.pdf
Dec 06, 2017 | Uniden Lands Phones
Can get answer machine to record callers message after you receive an incoming call
Uniden Customer Phone Number Shortest Wait Best Support
  • Phone Number
    800-620-7531
  • Talk to a Human
    Press 1, then 3, then 5. For the Marine products
  • Useful tools &
    numbers to call
    Compare all options
  • Call Time
    Average Wait: 46 mins - Mon-Fri, 8am-5pm
  • Did this phone number work? Yes No Update this, please
    Help force companies to improve customer service. How
Feb 17, 2014 | Uniden Lands Phones
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • Press the "MENU" button on your phone's handset.
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
No called ID
Does the LCD just display "Incoming Call"? if so please list your model number and I might be able to help you further.
Jun 23, 2010 | Uniden DECT 6.0 Cordless Telephone...
Uniden Cordless Telephone with Dual Handsets and Caller ID DXI-55
check if you have a manual. from there search up in the manual caller id settings. you have turned off the caller id option.
Nov 15, 2008 | Uniden Cordless Phone
GE 27938GE7_C call waiting
Yes, I re-read the manual and it says (under Caller ID) to press the flash/program button to answer the new incoming call...I must have hit the pound key in error thinking I hit the flash button. I have yet to try this in real time, but will next time it arises and report if it does NOT work.
Nov 09, 2008 | Uniden Cordless Phone
Uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
Aug 02, 2008 | Uniden TRU9488 Phone
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Nrupesh
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
Lands Phones Logo
341 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
