Question about Medion MD 7317 17" Flat Panel LCD Monitor
Medion AE19E1 (second hand)
Powers up then shuts off after 15 seconds. restarts with the monitor on/off button but goes off again. Green light goes orange when it switches itself off.
  • 54 Answers
Sir,,i think theres something wrong with the power supply,,,kindly checkthe power supply of it,,,thanks and hope to help you thnkss??
Posted on Jan 29, 2008
6ya staff
SOURCE:
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Jul 06, 2009 | Computers & Internet
Monitor light: green yellow green yellow etc.
Cycling of the power LED (about once per second) is typical of a switchmode PSU shutting down and trying to restart. Often this is accompanied by a tick each time, from the main switcher transformer.
Assuming you can open the monitor up (with the power OFF of course) check all the capacitors in the PSU for signs of leakage or bulging. Ideally you would check them with an ESR meter, but they are usually visibly failed when the monitor acts like this.
Replace any defective caps found and try it again while you have the case off, keeping your fingers well out of the way.
May 07, 2009 | HP L1706 17" LCD Monitor
EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
Mar 20, 2009 | Eiki LC XNB4 LCD Projector
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
Monitor goes dead AL1914
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Medion MD 7317 17" Flat Panel LCD Monitor Logo
378 people viewed this question
Top Medion Computers & Internet Experts
Ekse
Mark Snell
Thomas F. Schneider
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
