Question about Sony VAIO GRT250 Notebook
I want to open to clean heatsink but it is really tricky
  • kazieram Jan 29, 2008
    Thanks for help but I did it.First I picked up right speaker cover and then moved to the left.It was simple but i started from bottom and I haved problem.You just have to take out speaker cover and you can have acces to heatsink and CPU.So I cleaned everything.Don`t forget about one screw on your left.Aha one more thing.The thermal paste was like stone, it was hard to remove but polish remover did excellent job.
  • jp
    jp May 11, 2010
    can you expand on really tricky?
  • 105 Answers
It should look something like this picture just remove the screws and away you go.
hope that helps!
Posted on Jan 29, 2008
Sony vaio pg-6h1m over heating
Have you cleaned the fan, vents, and heatsink with a Can of Compressed Air? You may have to open the Laptop to clean thoroughly using Compressed Air and a light brush, use ESD protection as well. Improve air flow from the bottom of the laptop through to the side vents. A Laptop Cooler is a option. Hopefully you haven't done any damage to vital components due to overheating. Verify the fan is in working order and free of dust, obstructions.
May 26, 2013 | Computers & Internet
Hi am using sony vpccw21fx gets turn off quite often. when i use multiple programs and it also when i open a hd video or a game on the laptop.please give me a solution
The motherboard is getting to hot, it will need to be dismantled down to the main board, you need to verify the cooling fan is working properly, next remove fan and heatsink, get a can of compressed air and clean out all clogged ports and fan, now remove old thermal paste with rubbing alcohol and a paper towel and apply fresh compound to the processor and heatsink, small amount and spread evenly then assemble.
May 26, 2012 | Sony VAIO VPCCW21FX Notebook
My computer shut off by itself even though the battery was charged and the battery light kept blinking even after my computer was off. computer seems hotter than usual on bottom as well
It is probably shutting down to prevent thermal damage dut to overheating. Check that the fan is working. Even if it is, if the vents are clogged with dust the machine will not be able to cool properly. The only real remedy is to open the case, clean all the vents and fan, remove the heatsink, clean off old thermal paste and apply new paste before replacing the heatsink and putting back together.
Mar 14, 2012 | Sony VAIO VGN-S580B (VGNS580B03) PC...
My sony vaio VGN-CS215J cooling fan is to noise I dont no what to do
remove the covers and clean the fan with a brush for dust remove the heatsink and clean the surface and apply athin layer of heatsink solvent and fix it firmly in the processor
Mar 28, 2011 | Computers & Internet
I have a sony vaio vgn nr430e laptop the display goes off as soon as the cpu fan starts rotating
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Dec 09, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Overheating issue Sony GRT270P
Maybe it's wrong with your heatsink;youcan touch this:
Jun 27, 2010 | Sony (4-635-961-01) Laptop Heatsink
Sony Vaio PCG-K30 laptop does not work
By removing the heatsink and cleaning it, you may have wipe d the heat sink compund, or the heatsink is not well attached to the base and is not making full contact with the CPU.
Check for this two conditions, and correct them.
Everything should be fine.
Jun 10, 2009 | Sony (B99860307) for VAIO PCG-K series...
Cpu fan malfunction
Hello Chris....i highly recommend you dont "pry" on anything and it have it serviced by a qualified tech. The vaio incorporates the heatsink and fan as a unit, It's a 2 wire fan that is temp. controled from 5v and up. You can take a vacuum and place at the ventilation opening and remove some of the dirt & dust that has accumulated inside, this will help. The cost is around 100 buxs for a new fan & sink...Sony part # 1-763-483-12. Attached is a pic of the unit..; Also note: a depleted battery will effect fan operation as well.
Hope this helps and will fixya up....
May 18, 2009 | Sony VAIO GRV670 Notebook
Sony VAIO GRT250 Notebook Logo
47 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
