Question about JVC HR-S3901 S-VHS VCR
Older VHS tapes play 'sped up' on S-VHS
Older tapes (not ancient, but taped on our prior machine) seem to play at a high speed when inserted and set to play - why is this?
  • judyschmid Jan 28, 2008
    heads have been cleaned - we'll keep trying - thanks!
  • deltadoc Dec 01, 2008
    I bought a JVC HR-S3901/3911U VCR on EBay in July, 2008 used. It worked on my pre-recorded EP tapes made on other VCRs over the last 20 years just fine. About 20 hours of great playback, suddenly my EP tapes would speed up (both video and audio). I found I could hit FF for a few seconds and then hit Play and it would return to normal for about 15-20 seconds, and then lots of horizontal lines starting appearing on the TV screen until, the picture and audio both disappeared and all I had was the TV"s default blue screen. Then a few seconds later the video and audio returned only to repeat the problem in another 15-20 seconds. Haven't found any user accessible adjustments help (calibration, stabilization, tracking, etc.). The problem just started happening out of nowhere. THe last tape I played played fine, now all of my EP tapes do the same thing!
    deltadoc
    Novelist:
    Champion:
  • 254 Answers
A couple of possibilities: 1. One of the machines had a audio & tracking head alignment problem. If memory serves, tracking pulses are recorded on the bottom edge of the tape, and if one machine's head is slightly off, then these pulses aren't being picked up.
2. Do both machines have 3 play/record speeds? Many machines had SP, EP, & LP. Some didn't have EP, and if your older tapes were recorded in EP, perhaps this would cause your problem.
Both of these possibilities might be way out in left field.
Perhaps you could have a friend try your old tapes in their machine- in short, narrow down the defect. Is it the older VCR and it's recordings, or is it some goofy problem on the new one.
Lastly, you might check the audio/tracking head- see if it needs cleaning. This head is just to the right of the rotating video drum assembly.
Posted on Jan 28, 2008
How do i playback s-vhs compact cassettes ?
S-VHS tapes will only playback on an S-VHS machine, it will play them automatically when inserted. A normal VHS machine cannot play back an S-VHS tape.
Feb 27, 2015 | Televison & Video
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
WHEN INSERT THE VHS TAPE TO VCR IT EJECTS BACK... WHAT MAY BE THE PROBLEM?
Hi, depending on the age, chances r that some components r worn out or the eye sensor needs cleaning or sdjusting.....
Jun 21, 2014 | Panasonic Televison & Video
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Slow playback after recording.
Quality is definitely a factor here. Set tape speed to SP. Standard Play. It uses the most tape, and use a newer tape if possible.
You can also try converting to a newer format like MP4. This is the new standard for web videos. Older codecs might be an issue.
Sep 30, 2012 | Diamond Multimedia VC500 One Touch VHS...
Need to play a T-160 recorded in slp at normal speed to watch
This is automatic, as the record speed can only be manipulated, not playback unless youhave that setting which I have never seen,
May 11, 2008 | Zenith VCS442 VHS VCR
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
DRC 8335 Playing Back VCR Recordings in a Fast Forward State
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Jan 08, 2008 | RCA DRC8335
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
JVC HR-S3901 S-VHS VCR Logo
186 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
