Question about Microsoft Xbox 360 Console
Tray error tray keeps poping in and out of the cansole jams and will not read the disc
I have no idea
Posted on Jan 29, 2008
    Problem Solver:
  • 5 Answers
Try removing the faceplate as that sometimes causes the tray to jam.
Posted on Jan 28, 2008
Samsung DVD ht-c555 disc error
open it and try to reach the laser see if it have 2 pot. or 1 and regulate it 1 or 2 milimeters to the rigth see if it reads again, if not or if does not have any pot then try to clean the laser lens with ear cotton and alcohol very carefully to see if it works if dont new laser.
May 04, 2012 | Audio Players & Recorders
Xbox 360 elite console makes 2 weird noises and says open tray when putting in any discs.how to fix it
I've fixed open tray errors before, and if you are sure the problem is with the 360 and not the disc, it means you need to open the dvd drive and slide the laser over once or twice (at least based on my experience). BE CAREFUL. The mechanism that allows the laser to move around and read the disc is probably jammed.
Mar 20, 2011 | Microsoft Xbox 360 Console
I recieve an error code c 31 00 in my system. what do i do?
There's so much information missing from this question, but assuming this is a DVD changer, it's a disc error. Either the disc is upside-down or backwards and can't be read, is too dirty/scratched or unsupported and can't be read, or the entire mechanism is jammed or malfunctioning. If there are discs in the tray and you can remove them all, remove them and see if the error goes away. If the tray will not open, either take the cover off and remove the discs, or bring it to a service center.
Mar 17, 2010 | Sony Audio Players & Recorders
Cannot Read Disc?
I would say get a cleaning CD with the bristles on the Cd to clean the lens of the Wii. When you get it all it does is spin in the CD tray and clean the lens inside the CD tray. That should fix your problem the lens is probably dirty. If it doesn't leave a comment and ill try to help again.
Jan 09, 2010 | Nintendo Wii Console
Epson R265 the disc print tray keeps jamming
did you align the track? check the tray for any cracks, when you try to print cd's make sure that the printer and cd are balanced in a horizontal or even manner
Sep 12, 2009 | Epson Stylus R265 InkJet Photo Printer
My 360 dose not read discs but it dose spin them
Disc Error :- I have the same error. You can do 4 things.
A) You have to keep turning it on and off. Here's how... Turn it on, then click open tray then close tray ( keep opening and closing tray about 10 times) then turn the console off. Then keep repeating process for about 15-20 minutes and eventually the game disc will show up. ( I have to do this every time)
B) Make sure that this is covered by Microsof't's RROD warranty. Then some how get teh red rings on this console and send it to Microsoft. (Note: I am not held responsible for your actions.)
C) This is a lens problem. So go out to a store and buy a DVD lens cleanser. It's a disc that cleans the lenses of the DVD or the XBOX.
D) Open it up and replace the lens (like the above guy said) (much harder and more costly).
Pls rate my solution if it did help thanks.
Jul 25, 2009 | Microsoft Xbox 360 Console
PS2 HELP WANTED!!!!!!!
my friend had the same problem what he had to do was keep opening and closing the disc tray untill the 'reading disc' shows up and stays up but he got really anoyed with doing this so he got a new one shortly after this the ps3 came out...
Jun 17, 2009 | Sony PlayStation 2 Slimline Console
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
TRAYS ARE JAMMED
hi, there must be a disk previously inserted which has stuck in the tray or something, open the cover and check if anything is preventing the tray from ejecting.. let me knoiw
Dec 28, 2007 | Philips MCM530 CD Shelf System
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
