Question about Dell W4201C 42 in. Plasma HDTV
Picture failure my picture will go out for a few days then come back on for a few days and keeps doing this. What could be the problem?
  • 1 more comment
  • cmptrlv Feb 15, 2008
    I have the same problem. My Dell just went out without warning. Powers on but no pics with PC, cable or video device.
  • giovannic Mar 25, 2008
    I just took the set apart and found that the sub supply was the problem so i ordered one on ebay and replaced it myself. It was very simple. This set has a power and sub power supply so I just switched them both out since I had it opened...
  • Anonymous Apr 02, 2008
    I have sound,but no picture.
Possibly Power Supply...(70%). Other 30% Y-Sus or X-SUS
Posted on Mar 25, 2008
VIZIO M801d-A3 No picture, no sound, passes flashlight test. Picture and sound went out a few times and then back on in days before total failure. What do you suggest for repair?
Main board controls the audio. Measure the different voltages produced by the power supply board to see if they all are present and within specs.
Jul 31, 2017 | Vizio Televison & Video
Keeps taling longer for tv to start
Probable power supply decline to failure.
Dec 28, 2013 | Toshiba 46XV640U 46 in TV
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
We just moved the tv into our new home, when we plugged it in and turned it on nothing happens.. no picture or sound, the timer/standby red light blinks 11 times then nothing. We have tried powering it on...
Well I think what has happened is that the move has caused a failure, it well may have been bumped or jostled, these units are VERY delicate, and should NEVER be moved without using the protective crating, they came that no-one keeps, for any transport, (It is absolutely imperative that you keep your packaging these days as it should NEVER ever be moved without putting it back into that packaging for travel) they really do NOT travel well at all. This what you describe is a classic situation, we see it all the time in my shop. You have little option but to get a "Quote" for a repair. this is indeed unfortunate, but all too common from "shifted" item. Especially TV's.
Mar 22, 2010 | Televison & Video
Screen keeps cracklin then picture goes off its doing it evey few mins i have to turn it off then back on again to get pic back
This is the same problem I've been having. My display died a few days ago. Repair guy said walmart will end up replacing it or refunding my money. had this tv for just over a year
Feb 23, 2010 | Philips 47PFL7403D 47 in. LCD TV
LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Apr 10, 2009 | LG 32LB9D TV
Sony Wega KF50WE610
5 red blinks = lamp driver or ballast failure.
we610 part # = 1-468-798-14
replacement is straightforward when you unplug the set and open the back up. remove the metal support bracket to expose the ballast. make sure to keep all wires routed as you found them.
Nov 22, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Dell W4201C 42 in. Plasma HDTV Logo
70 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
