Question about Lexmark X7350 All-In-One InkJet Printer
Ink Cartridges How do you put the ink cartridges into the lexmark x7350
    Problem Solver:
  • 19 Answers
You should be able to open the printer below the scanner. The printhead should move to the center of the printer. Then you open the clips holding the cartridges and remove the old. Replacement cartridges click into the same slots. Then you secure the clips and close the printer.
Posted on Aug 27, 2009
Can u help me with resetting my Lexmark x7350? i revilled my cartridges, and now the printer says my color cardridge is allmost empty. Thank you!
Once the Lexmark cartridge is refilled, it can no longer report it's ink level. ). You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
May 24, 2011 | Lexmark X7350 All-In-One Printer
I have a lexmark all in one X7350 and it appears as if the color ink cartdige is full, but I cannot print any images in color. Any suggestions?
remove the ink cartridges and clean the nozzles out with rubbing alcohol. when cartridges and empty and not replaced with 24 hours the nozzles will get plugged up the nozzles of course are part of the printer were the ink flows through as received from the ink cartridge
Jan 14, 2011 | Lexmark Office Equipment & Supplies
Need to know how to install ink cartridges
Perhaps the Lexmark X7350 User's Guide will be able to help you. Just click on the link to download: Scroll to Maintaining the printer, Page 70, for the instructions on how to install the ink cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source.
Thank you for choosing Lexmark.
Aug 27, 2010 | Lexmark X7350 All-In-One InkJet Printer
I have replaced the cartridge in my X7350 but still shows as low
As long as the cartridge operates OK, do not be concerned with the ink levels. It may just be a problem with that one ink cartridge and at some point, it will run out and then replace it. Cartridges made by foreign sources may not even show the ink levels, and that is not a problem when using them. Printer manufactures try to make it ******* customers as they want you to pay more for their cartridges.
Feb 20, 2018 | Lexmark X7350 All-In-One InkJet Printer
I ordered Lexmark 32 & 33 ink cartridges off ebay (but they are not 'genuine'). I'm getting an error message #1203 - 'Consult your user's guide'. Does my Lexmark X7350 only accept Lexmark brand...
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Nov 30, 2009 | Lexmark X7350 All-In-One InkJet Printer
What kind of ink does it take....cant find the x7350 anywhere on the online there another model that takes same cartridges
Okay will have and does sale the ink for this printer as I checked this uses the 7000 series ink. I have done the homework on this for you now also what you can do is this pop out one of the cartridges take it ot a office depo and they will match the numbers on this. there is no need to worry this is a very nice printer and you will find the ink for it. Please use only manufacture ink and not refills you will reduce the lifespan of this by doing so.
Thanks and please do rate postive on your free solution today!
Nov 16, 2009 | Lexmark X7350 All-In-One InkJet Printer
Refilled cartridge , printer says right cartridge incorrect
Lexmark builds intelligence into their cartridges and printers to prevent the use of refilled cartridges.
Lexmark has never approved the use of anyone else's ink for their printers primarily because there is no way to prove the quality of the ink.
Please purchase a Lexmark cartridge.
May 09, 2009 | Lexmark X7350 All-In-One Printer
Lexark X7350
If the contacts are different, then you may have bought a damaged cartridge, or just simply the wrong cartridge and this would explain why your printer cannot recognise the cartridge. Make sure you bought the same number Lexmark cartridge as the old one. Return it to the store as a damaged cartridge if it is the exact same cartridge. Lexmark would not change the design of a working cartridge to exclude customers from using a printer.
Sep 07, 2007 | Lexmark X7350 All-In-One InkJet Printer
Incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X7350 All-In-One InkJet Printer Logo
122 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
