First some background.
The use of 901's Active EQ (or any external processor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them, in your case maybe the CDR or DVR/VCR outputs. On many AVR's, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others (yours), you have to borrow the signals from a typical CDR or DVR/VCR Output RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's.
http://www.retrevo.com/support/Pioneer-VSX-520-K-Receivers-manual/id/23653ag911/t/2/
This works for all models of AV receivers when you want 901's as Front L&R speakers...
