Question about Dryers
WHEN I PLUG MY TUMBLE DRYER IN IT TRIPS THE ELECTRIC AT THE FUSE BOX. I DONT EVEN HAVE TO TRY AND SWITCH IT ON
  • 3 more comments
  • ALLYBO Jan 28, 2008
    THE POWER CABLE WAS TOO SHORT TO REACH THE NEAREST PLUG AND I WAS RUNNING IT TO AN EXTENSION CABLE. I THOUGHT THAT IT MIGHT BE A PROBLEM WITH EITHER THE DRYER CABLE OR THE EXTENSION. I HAVE REPLACED THE DRYER CABLE WITH A LONGER ONE BUT THE PROBLEM IS STILL THERE
    SORRY. ALL THE CONNECTIONS ARE FINE. CHANGED THE SPADE CONNECTORS AS WELL AS THE NEW POWER CABLE
    YES. CONNECTED IT ALL BACK UP THE WAY THE OLD POWER CABLE CAME OF
  • ALLYBO Jan 29, 2008
    HI,
    SORRY I GOT CALLED OUT TO WORK LAST NIGHT. THE TUMBLE DRYER IS AN INDESIT IS70C.
  • ALLYBO Jan 30, 2008
    HI,
    TOOK THE BACK COVER OFF THE MACHINE TO CHECK THE HEATING ELEMENT. ELEMENT WAS FINE. PUT THE COVER BACK ON AND TRIED MACHINE OUT OF CURIOSITY AND IT WORKS NOW WITHOUT TRIPPING THE ELECTRIC. ??????????????
    President:
  • 1,314 Answers
Take the cover off the cord to the drier and check it to see if any connections are burned or loose the middle of the cord should be in the middle of the terminal block let me know what you find
Posted on Jan 28, 2008
  • 4 more comments
  • robert samples Jan 28, 2008
    then check your out let you still havnt said how the connections are is the middle wire to the middle connector
    sorry im not making my self clear there are three connecters on your cord the connecter in the middle of the cord must go to the middle of the terminal block are they that way
    then turn off the breaker and check the outlet what is your model # and brand
  • robert samples Jan 29, 2008
    whats the brand and model number
    check the heating element to see if its broken and touching the body of the drier that wii do it
  • robert samples Jan 30, 2008
    great
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
My indesit tumble dryer idv65 runs for 10 mins and then trips the electric and stops
if its an old dryer its probably the motor thermostat heating up and shutting the motor down ,replace that or even the motor
Jan 14, 2013 | Dryers
My electric trips out when I switch the tumble dryer on
Sounds like the plug cord is wired wrong on the dryer, or the breaker is too small or going out. Or the heat strip could need to be replaced.You should have a 30 amp breaker for the dryer. Check the heat strip then your breaker.
Sep 02, 2009 | Hotpoint Dryers
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
I get e01 on ge dyrer panel
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE;
Aug 22, 2008 | GE DCVH515EF Electric Dryer
The drum doesn't rotate and a strange buzzing noise occurs
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Aug 22, 2008 | Zanussi Dryers
TUMBLE DRYER
Allybo check how the power cord is wired to the dryer. I have seen where the hot wire has been attached to the ground of the dryer and this will create a short which will trip the breaker.
Jan 28, 2008 | Dryers
Dryers Logo
257 people viewed this question
Top Dryers Experts
