Question about Avocent CPS 1600 Networking Switch
I can't configure my CPS1600
I am using a regular straighthrough cable, and i bought from RadioShak the DB-9 Adapter and made sure that all PINs are matched correctly to what is listed in the manual. However, i am unable to connect to the device using Hyperteminal.
Please help!
You used a straight cable with all the pins matching. But you may need a rollover cable instead for the adapter you've built (as in a RJ45 cable that reverses al pins). Or make the PINs for DTE (mirror image of the PINout shown in the manual) Without actually seeing the manual, i'm guessing that they show you a diagram of which RJ45 pins correspond to which serial PINs from the DCE's point of view.
eg
Connect your TX to other side's RX (so the other side _receives_ the bits from your device's TX pin)
Connect your RX to other side's TX,
Connect your DTR to other side's DSR
Connect your DSR to other side's DTR
Connect your RTS to other side's CTS
Connect your CTS to other side's RTS
Posted on Feb 27, 2010
    Problem Solver:
  • 5 Answers
The CPS600 is controlled and configured with the java based vConsole software. vConsole is provided by Avocent. I personally haven't worked with Avocent hardware much myself, but from what I can tell CPS1600 is designed for a UNIX based network. It should work on a windows networks as well, but you may need to do the CCM firmware conversion or update the CPS firmware to enable the device to communicate with a windows machine. I would recommend to forget about using hyperterminal and try the vconsole software, and if your still having trouble, then go for the firmware update and the ccm conversion as a last resort. Here is the link to the Avocent site, you should be able to find all the necessary software & firmware there. If you do end up needing a Unix system to configure the device, you should be able to get away with using the knoppix livecd linux distribution. Its a bootable cd with a fairly user-friendly version of linux.
www.avocent-europe.com
- Shawn
Posted on Jan 31, 2008
I bought a x2gen mg5r4 monitor at the goodwill I've got a power adapter that supplies the proper voltage & amperage to the monitor. It powers up just fine, but when plugged into the computer it (the
If the monitor indicates "No Sync" Make sure your video cable is a high density DB15 end. If it is only 9 pins, you have a DB9 cable or connection. Also make sure the video you have it attached to is enabled and is also a high density DB15. (it will have 3 rows off pins. The DB9 will have 2 rows)
If those are okay it may be broken wire in the cable or on the monitor's DB15 connector/connection.
Dec 18, 2011 | Computers & Internet
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
Hi! What cable/adapter should I buy so I can use foot pedal in my laptop using USB? Foot pedal is 9-pin, used for transcription. Thank you.
The following link should meet the requirements assuming your existing cable is defective.
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10311&cs_id=1031104&p_id=2276&seq=1&format=2
Feb 28, 2011 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Need a configuration wiring rs232 9 pins to two wire output
To communicate two devices with RS-232 ports, at hardware side you'll need 3 wires, Tx, Rx and GND, with DB 9 connectors at both sides ( A & B ) you have to connect 2A to 3B, 3A to 2B, 5A to 5B, if side A is DB-9 and B side is DB-25 the connections are 2A to 2A, 3A to 3B, 5A to 7B, at software level you'll have to setup ports as hardware handshake none, of course, working at the same parameters (speed, data bits,parity).
Feb 16, 2011 | Computers & Internet
RS 232 cable manufacturer
Is 25 pin or 9 pin connector?
In either case pins 2 & 3 are Tx & Rx data, you might have to swap them.
On DB-9 pin 5 is GND, on DB-25, Pin 1 & 7 are GND.
Here is a link to a reliable source of pinouts for you to construct your cable.
Apr 06, 2009 | Computers & Internet
My apple mini mac (no intel) hook up mag monitor 780
The Mac Mini has an adapter plug, DVI to VGA.
If you use the adapter and a VGA cable to the monitor there is not a noticeable difference.
Just be sure to know the resolution maximums of the MAG monitor before you think its the Mac.
Feb 15, 2009 | Mag Innovision LT776s 17" LCD Monitor
Driver needed
I found my disc. Problem solved. Thanks for follow-up.
Jan 11, 2009 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Meaning of Db and the use of Db9-male Cabl
The D is the shape of the connector when looked at it on it's side. The second letter (A,B,C,D,E) defines the amount of pins in the D connector. "DB9" is actually called DE by the standard and the E=9 pins. A=15, B=25, C=37, D=50, E=9. This standard was set in place by ITT Corp (Not the school) in 1952, and DE-9 connectors were used for tons of applications. (Machinery, Cars, etc). If you are only referring to the computer uses, the connector is widely known as RS-232 or a "Serial" port. These ports in computers were/are used for devices like early printers, scanners, networking hardware, or even as a method of connecting to the Internet at one point.
Dec 05, 2008 | Parallel 6 Foot DB9 Male - DB9 Female Null...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Avocent CPS 1600 Networking Switch Logo
246 people viewed this question
Top Avocent Computers & Internet Experts
gary433
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
