Question about Maytag MAV7600 Top Load Washer
Maytag MAV7700, Grinding and water leak
Washer makes a grinding sound when the tub finishes its spin cycle (When it stops)
Also, wife left water in machine last night to soak some clothes and we found water on the floor this morning. Where could the leak be coming from?
I checked under machine but all I can see from there are the pulleys and belt.
  • 770 Answers
Open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Posted on Jan 28, 2008
My Maytag PAV2200AWW Washing Machine makes a noise like grinding or metal-metal contact during the agitate cycle. How can I fix it?
The sounds of 'metal grinding/banging" begs the question of whether or not its even safe? If you hear that sound all the time or as you say ONLY during the agitation cycle suggests that you be able to service the tub/motor mounts in the underneath chass--which is a heavy-duty technician job. A Maytag technician has the tools you need. Or the obvious...get another one from a friend who is upgrading to a new washer and hands it down to you for a little change.
Dec 12, 2015 | Maytag Washing Machines
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Maytag washer model MAV6200AWW
pop off the front panel and look at the inside of it,if you see black dots on the bottom half and on the other walls like half way up from the bottom you have bad tub seals,the seal is made of metal and rubber,when it leaks and in spin it will shot out water and it will be black from the rubber,also you can fill it as high as it will go,then turn the timer to spin and watch where the tranny.and tub meet,if it sounds like marbles spinning and grinding and water leaks out it's the seals.if so time for new washer
Jun 23, 2013 | Washing Machines
My Maytag MAH-24 Washer suddenly started making a clunking grinding sound in the middle of the spin cycle.
The rear tub bearing is going out, and the cost starts normally about the 450 and up range,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Maytag MAH2400A Front Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Atlantis MAV7700
Got to take front cover of washer to get  at the screws to take out... to get lid to lift up
Sep 15, 2007 | Maytag MAV7600 Top Load Washer
Maytag MAV7600 Top Load Washer Logo
204 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
