Question about Sony Ericsson Walkman® W880i Cellular Phone
SE w880i case
Hi, have an SE w880i and have full new case to put on, i have undone the 2 tiny top screws and the front casing comes nearly off but appears to be stuck. are there anymore screws at the bottom that i am missing??
Any help would be greatly appreciated
Thanks
Take sticker off bottom of mobile where it says walkman use a thin blade to gently pull it off there is two screws behind it ok m8
Posted on Feb 10, 2008
    President:
  • 1,944 Answers
I have Prem-I-Air DD122FWMK3 Desiccant Dehumidifier tht has stopped extracting water. I have got a replacement heater element for it but I can't even get the casing off! Got the screws off the bottom but...
In most DD122's there are 2 screws under the handle, o the handle will need to be removed to gain access to these. There are another two screws that require removal of the dust filter. Once all screws are undone, flip the unit onto its other side (back facing the floor) and take it apart that way. This is much easier.
Dec 03, 2010 | Dryers
Drum Rubbing on top of the dryer case.
you have to undo the whole thing including the door then remove the drum then you will have acces lots of screws but hey better to do it then paying 250$ for a guy to do it its a week end project :) and beer
Sep 19, 2017 | Kenmore Dryers
How do I replace the lid switch on a Kenmore Model 110.82681110, bought in 1987?
If you allready have the new switch, you are ready to start. If you do not have the part, it is available at www.sears.com under the parts direct tab. you'll need your model number to search out you machine and then the switch.
I find it easiest to remove the entire main case to make this repair. Case removal is as follows:
Disconnect the power cord. 1. There are two screws, one at each front corner, holding the control panel in place, remove them. 2. Remove the two screws at the top, on the back of the control panel. Carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the front of the clips, at the back corners on the top and push back to release them, once again take note to their positioning. 5. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Replace the switch and reassemble reversing procedure. Good luck. Need help? I'm here. Just enter a comment and Fixya will send an email to me.
Aug 01, 2009 | Kenmore 24032\24036 Top Load Washer
The backpanel won't come off why? the screws are out
I always miss a screw on LCD Tvs ,they hide screws everywhere. Sometimes they cover a screw with a thin plastic disk so you can't see the screw. Also on some TVs the PC connector has 2 tiny bolts that need to come off. Check around where all your cables go for tiny screws. Also if you still have the pedestal on sometimes they hide screws underneath. once you're sure you have all the screws out gently start pulling/shaking out from the bottom of cover.This usually works for TV 32" and over. Tiny LCD covers are snapped on kinda like how a remote control is put together. You might need a small thin bladed screwdriver to wedge between and gently move and twist when you get near the snap locks.Hope this helps.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 27, 2009 | Televison & Video
Brother SE-270D balance wheel is very hard to turn manually
This is the first and foremost problems that I've found: The bobbin case is packed full of threads. The needle is crooked and must be replaced.
1. The bobbin case has a hook that turns to catch the top thread when the needle is down. The bobbin case assembly must be removed and cleaned totally. The bobbin case assembly is where the bobbin sits. The bobbin case has a black bar that sits on top of it. Listen the forward screw and slide the bar slightly. You will need to move the hand wheel to move the hook to the front-most position. When you have done this the bobbin case will come out easily. Clean it thoroughly and put one drop of oil on the track. This is a lower spot where the bobbin case sits on top of. Before you put the bobbin back in you need to check the tension. It is intended to be even with the top tension.
2. Replace needle and make sure it is in totally and is seated the right direction.
HOPE THIS HELPS
Apr 14, 2017 | Brother SE-270D Computerized Sewing...
Please, Please, Please Write Back !!
At the back of the phaone at the top you`ll find 2 rubber circles flick them out and there is 2 screws there on the front of the phone at bottom where it say`s contract name ie:vodafone peel that back and there are 2 more screws under there then prize case open
Jun 24, 2008 | Sony Ericsson Walkman® W880i Cellular...
HELP!!!
Replace keypad is easy.
Remove the metallicsticker on the front to expose 2 screws, remove these, remove the two rubber stopper at the top on the back to expose two screws, remove them.
Take the battery cover off and unclip front. Keypad falls out of front housing.
Replace and reverse procedure.
Is there a secret to getting the plastic cover to separate to adjust the belt for the Singer 7462?
These split cases are a right pain to put it mildly..........
Before we go further, you have got the handwheel in the sewing position, not for bobbin winding, haven't you ?!?!
OK, sorry, but it's like "turn the thing on at the wall guys"....often simple things are overlooked.
So here goes..
Although you may think you have undone all the screws, there are usually several that merely clamp a small lug, so a half turn to looses is all you need, not to undo completely, as they are not passing through a hole, merely a U shaped retaining lug attached to the casing.
They may be near the bobbin case/hook race area at the back of the machine, but undone from inside at the front.......around near the needle arm is another favourite spot to clamp front and rear sections.........some of these machines from various manufacturers have more than 12 retaining screws !!!!
There is also a tricky one that is a 2mm hex bolt (Allen Key) that is accessed through the air vent flutes under the handwheel near the power inlet !!
I hate them all, and I have service manuals (for Janome at least) to tell you where to look !!
Different makes and models have differing places to look.......design by committee to save manufacturing costs and keep technician stress at fever pitch.
The other loathesome thing, is to do with the small clips moulded to either side of the joint .....they seem designed to push together once only, in the factory before boxing and distribution........they are NOT friendly if anyone needs open it again to service the machine some time later and are easily broken off.
....a couple of small screwdrivers to lever and wedge an increasing section apart can work, but do not force anything that does not want to come easily, you may not have undone all those screws the first time............
My absolute best advice for these is to take it to a technician who has the service manual for your model or you will almost certainly have broken clips and an ill fitting case, plus the ensuing anguish and fury of the person whose machine you didn't fix.
By all means have a play at it, but if there is any danger of frustration and the temptation to force something, get up and put the kettle on immediately, then call for backup.
May 28, 2008 | Singer 7462 Mechanical Sewing Machine
LG VX8300 broken camera lens
hi is it the outer case of the phone that has the crack or is it actually the lense of camera as often it is the cover over the lense that gets broken as the lense on the camera itself is tiny.
If this is the case and it is just the case that needs replacing you can either take it to phone shop and they will replace for a small fee the only problem with doing it yourself is the screws need to be undone in a certain order and the same putting them back getting this wrong can warp the board and destroy the phone.
The only sites i have found that shows you how to strip phones down only covers nokias.
You could try using ask.com and typing in what you are looking for as sometimes you will come across a site containing the info you need.
If the problem is with the camera itself this will require unsoldering and a new camera soldering back onto the board but you problem is probably just the case.
They are difficult to take off as once you have undone the screws their are clips holding the case onto the board itself and if you damage these you wont be able to get the phone back together again.
Ill have a look now for you and see if their are any sites with instruction on for you and will post back if i find any but try using ask to search for you you might be lucky let me know how you get on ok
Dec 29, 2007 | LG VX8300 Cellular Phone
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
Sony Ericsson Walkman® W880i Cellular Phone Logo
123 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
