Question about Motorola Mobility RAZR V3
Key pad light
My keypad lights up when I turn it on , But it will not come on otherwise
  • 2 more comments
  • 91dodgeram Jan 29, 2008
    I have the original Razr V3 and I can not find A setting for battery safe mode.
    Cingular...Actually I think Its an Original Cellulure One phone.
    I know there is no need to light it in the day time. I Tried, it Sill nothing..Is there a replacement sensor for it?
  • 91dodgeram Jan 30, 2008
    Thank You.....Thank You very Much....All man me and the kings gonna fix her right up...Huhhhhhhhh
Thanks i had the bat saver on it solved my key pad light
Posted on Oct 09, 2008
  • 2,130 Answers
Sounds like you have the "Battery Save" feature set to "ON". Go into settings and set the "Battery Save" feature to OFF.
Good luck.
- Jim
Posted on Jan 28, 2008
3 Suggested Answers
trendsetter
  • 43 Answers
SOURCE: mobile phone
hi,
in ur phone go to settings, select display settings, now select the keypad lights feature on..its very simple.....
good luck
Posted on Jul 04, 2008
SOURCE: keypad light wont turn on
That is normal operation for Motorola Slvr L7 phones, don't be alarmed. The Motorola Slvr L7 has a built-in light sensor that disables the keypad light once light is detected by the sensor, if it doesn't detect any light, the keypad light automatically comes on.
The light sensor is located on the top of the phone next to the clip that releases the cover at the back. To test the light sensitivity, you can try blocking the light sensor with your finger and touch the keypad to see how it functions. You can also place the phone in a dark place and touch the keypad, the lights should come on, put the phone where there is sufficient light and press the keypad, it should not come on.
Try it and see how it works! It's a feature of the phone, no big issue here! Probably to conserve on battery life, you wouldn't want the keypad light on when the place is bright. I think it's a great feature.
Posted on Jul 22, 2008
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Thanx
Jul 26, 2010 | Nokia E71 Smartphone
I have a problem with my Nokia 6600 slide. The key pad light does not work. It makes no difference if it is light or dark. How do I turn it on?
open up your phone you'll need phone screw here.than you can check keypad connector,clean up with an pencils eraser(its safety) usually keypad or keypad light problem because off dirty connector.good luck.
May 21, 2010 | Nokia 6600 slide Cellular Phone
Oven light switch on keypad not working
Could be a bad key pad -or relay not energizing in the electronic control.
You would have to do an ohms tes on the key pad to verify
\Affordable Appliance Repair
Lake Forest,CA. 92630
Aug 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Combination on car keypad does not open doors
Does the key pad on the door light up? Are there any tears in the key pad numbers? Does the key pad lock the doors?.
There are no fuses directly for the pad.. The key pad is linked directly to the RAP. module. If the locks work from the FOB the fuses for the Module are good. Chances are the pad is no good especially if it don't light up. The RAP module is above the driver side foot well, directly above the accelerator pedal . Hope this helps.
Mar 09, 2009 | 1999 Ford Taurus
HP povilion entertainment pc laptop unable to use the keypad
you just have to click da little button in the center top of the keypad nd the little red light will turn blue and you can continue using your keypad
Feb 18, 2009 | HP Pavilion dv6000z Notebook
Key Pad Light
Keypad light is turned on and off by sensing whether you are in light or in dark.
The phone turns off the keypad light when you are in sufficient light conditions.
Oct 29, 2008 | Nokia N72 Cellular Phone
Mobile phone
hi,
good luck
Jul 03, 2008 | Motorola Mobility RAZR V3
Key pad
Have your phone to be checked to a repair shop... it may need replacement... before that, check the phone settings to turn on the keypad light they might be disabled.
Feb 26, 2008 | Motorola Mobility RAZR V3
Touch-pads unresponsive
Some newer models have a child lock feature which can be accessed via a HELP or CUSTOM HELP pad. On recent LG models, try pressing the "0" key for 5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Has anyone ever sprayed cleaner directly on the keypad? Has anyone ever boiled on the stovetop without running the hood vent fan? Is the hood vent clogged? Any of these can cause moisture buildup on the control circuit board or in the keypad, which can cause odd problems like this. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Please let me know if I can help further: http://tinyurl.com/yzjozk
Sep 22, 2007 | LG LMVM1945 Microwave Oven
Motorola Mobility RAZR V3 Logo
173 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
