Question about Samsung RS2630SH Side by Side Refrigerator
Repair My temp readings on the front of my fridge read -18 and +3 but the temps inside both are not what it says, If I switch the fridge on and off the compressor kicks in and the true readings come up, once the temps come back down to -18 and +3 the fridge and freezer starts to become warm again but the temps for both stay the same -18 and +3. I have the same problem and I keep turning it off and on now I'm worried something else happens to the fridge.Could you help me solve the problem or get someone to do it? just to remjnd you that the temprature inside the fridge and freezer is more than what is showing in the side of the door and if I turn it off and on it will show me the right temp which is much higher than what it should be.could you help me?
  • 3 more comments
  • aryaparisa Jan 28, 2008
    what is the thermistor?
  • aryaparisa Jan 29, 2008
    yes I have checked the thermistors as well.They seem to be working well.
  • lewisinozjor Jul 26, 2008
    We have the identical problem on ours - Fully defrosting has not fixed the problem, it still is occuring. Can anyone tell me what specifically needs to be done/replaced etc. to fix it please? Any information would be very much appreciated.
    Many thanks.
    Sabina
  • Gary Davd
    Gary Davd May 11, 2010
    A thermistor is what is in the refrigerator and freezer it senses the temps via resistence and tells the display board what the readings are like the old style temp bulbs on ref. thermostats
  • Gary Davd
    Have you checked the Thermistors
Seems like its not defrosting in the fridge. remove rear panel and look for ice around the thermister.
Posted on Feb 12, 2008
FREEZER NOT FREEZING AND FRIDGE FREEZING
please provide your model number it's impossible to help you without it
Appliance 911 Sea Breeze
Jul 31, 2015 | Refrigerators
Fridge freezer
HI jACQUELINE.well i reckon the fridges r a bit temperaMENTAL.:).Before u do anything well u can check weather u have ice build up on the rear panel inside freezer compartment.either way i would first turn it off for 24 to 48 hours.then remove bottom plinth panel (bellow the door).thoroughly clean condenser coils right to the end.then try u could get lucky.if it doesnt work then the problem could b inside the panel.def/heater,fan motor,t/stat,or the board.good luck Ali
Aug 24, 2012 | Refrigerators
Model cth18eatfrwh. freezer freezes,but main storage section is warm enough to read "spoilage" on my inside thermometer. what can i do ?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Refrigerators
Whirlpool side by side Refrigerator not cooling, two -- where -18 temp used to be.
the fact the bowl was filled with water and that you said the inside of the freezer was coated with ice, indicates a failure of the defrost system.
now the ice has gone, reset the temps and wait to see what happens
Oct 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigeration problem
Sounds like a main board problem cause the temp should not be accurate one minute, then way off the next. I would have someone look at this cause it would be difficult to figure this out without being there to troubleshoot it
Jan 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
It sounds very much like control board problem. The chances of both sensors at fault seems unlikely. Unusual that it is the exact same temp unless they are your setpoint requirements. I would advice contacting reliable fridge guy to check the cabinet. Hope this is of some if not much help.
Sep 14, 2007 | Samsung RS2534 Side by Side Refrigerator
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
113 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
