Question about HP Pavilion dv6000z Notebook
My laptop wont start
I have a sony viao and it wont start up...The pane shows that the battery and stuff go on but the screen seems dead... Help!!
    Genius:
  • 1,067 Answers
Have to buy a replacement screen buy them on ebay cheap notto hard to install
Posted on Jan 28, 2008
I have a sony viao laptop and i dont want to use the battery when i am going to use the laptop..Is it possible and will the laptop cannot be harm???
Yes it is possible and no it wont hurt the lappy.
Not sure why you would want to do this as even a dead battery can be left in the lappy without causing damage
Sep 09, 2012 | Sony Viao
My Sony Viao wont stay charged and when i try to power it up, it shuts down by itself at the sign in screen. It wont let me get past the sign in screen,
Are you using a Sony Battery or an aftermarket cheaper version?
If your battery has been changed to a different brand then thats your problem and a whole problem in itself.Not saying there is anything wrong with that, but the Sony ISBmngr.exe file will stop the charging of any battery exept Sony's and put the system into hibernation mode. ( website with Info below)....
If you have the original manufacturers battery then go on.
This is the typical charging-plug, jack, for laptops. Many times the plug itself is bumped over time and pushes on the pin in the center. The charging time becomes very short, if at all, because the connection is broken.Some are completely or because of the position of the wire holding it just right long enough to give a short charge.
32917b9.png With a Voltmeter ,check the output of the charger itself to be sure it is working properly.
Although VIAO has been out for a while & because the model was not listed here the age of the battery may also be in question. If the battery has shorted out and the charging unit & jack are fine then a bad battery that has shorted will cause you symptoms also. Try removing the battery and running on the charger alone.
Here are a couple of sites that I found that deal with Sony VIAO's
1. http://www.ghacks.net/2008/02/02/sorry-you-cannot-use-that-battery-because-it-is-not-made-by-us/
2. http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
3. http://sarabannerman.blogspot.com/2007/04/sony-laptop-battery-mal-ware.html
Oct 04, 2010 | Sony VAIO VGN-CR220E/P Notebook
My sony viao laptop has gone into sleep mode or just wont start up. I have started it and have seen the viao splash screen and then it looked like it was gonna load but went to a black screen now I cant...
try to restart your laptop in SAFE MODE WITH NETWORKING. once you are in safe mode with networking change power settings from power option in control panel. Try SYSTEM RESTORE. Still you face problem press F8 when you turn your laptop on. You will get advance options. Select LAST KNOWN GOOD CONFIGURATION.
May 04, 2010 | Sony VAIO VGN-S460 Notebook
Screen is dead
  1. turn off the computer
  2. take off the ac adapter and remove the battery
  3. reseat RAM/memory
  4. without the ac adapter and battery, press and hold down the power botton for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
hope this helps
Mar 02, 2010 | Sony Computers & Internet
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
I have a sony viao vgn-c210e. but there is an x
u r laptop battery has dead u need to replace it
Jul 29, 2009 | Sony VAIO VGN-C210E/H PC Notebook
Dead loptap
how suddenly? like everything was fine then wont go on now? or things were acting strange then - dead? their can be two to three things that have happened, dead battery (flat or split!) blown fuse in the AC TO DC stepdown on the mains power cable. (the box with the little light on the power cable.) or component falure. this will only likley happen if you drop it while its on or similar tho. unless its new? my first idea would be to see if its stil under warrentee then look at a repair quote i would do a job like this for $270 if its a component fail or $150 if its a power systems fail! so dont get ripped of :) ask which one first. good luck!
Oct 08, 2007 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
HP Pavilion dv6000z Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
