Question about Maytag Performa PAV2200
Maytag Perfoma 2300
My connection hoses leak at the washing machine end. I bought new ones and this did not help. I am so frustrated.
  • 1 more comment
  • eatpoop Jan 28, 2008
    They are brand new hoses and washers. Thanks tho.
    Does anyone know about the fill valve? It is where the hoses actually connect into the machine. It is plastic and maybe the plastic is cracked or the piece may need to be replaced. But I can't determine if this is a fix.
    The washers were separate and I had to install them in both ends of the new hoses. I still want to know about the fill valve? Thanks
Pressure hose
Posted on Feb 09, 2008
    President:
  • 1,314 Answers
Check to see if they have rubber washers in them
Posted on Jan 28, 2008
  • robert samples Jan 28, 2008
    just because they are brand new hoses doesnt mean they have rubber washers in the end of them did you look
    yes it is
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
Why when washing machine ends cycle it keeps leaking water
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Dec 02, 2012 | Maytag Neptune FAV9800AW Top Load Washer
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Water will not fill.
If no water comes in on hot or cold, replace the water valve. That is the valve the hoses connect to.
Mar 21, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tub leaks water during cycle out bottom onto floor
We had the same problem. There was a pinhole leak in the hose that connects the tub to the pump. Bought a new hose for under $10 and fixed the problem ourselves.
Feb 26, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300AWW Washer leaks while filling
Hello
Welcome to Fixya
My name is Huum,
Why did you change the hoses with old ones?
If you are going to change them use new ones!
Sounds like the drain hose connection to the washer is not tight or not secured, or not fitting th connection because it is from a different washing machine.
Or there is a hole in the inner tub and leaking out on the floor.
Do you know the ones that sold it to you?
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
Dec 14, 2008 | Maytag PAV2300 Top Load Washer
Leaking tap?
leaking on faucet end? probably bad o-ring in fauct head ..leaking on washer end? possible hose is cross threaded on inlet valve take hose off and try to reconnect watching closely as you tighten trying not to cross thread plastic connection can sometimes be recut
Aug 29, 2008 | Washing Machines
My Maytag Performa 2300 appears to have grease leaking out of the point where the top of the agitator connects with the bottom of the agitator.
Get a new one. You either have a bad tranny or a seal leak. Either way the cost is about 60 - 80% of the cost of a new one.
Aug 04, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
