Question about Acer Aspire 3050-1733 Notebook
3050 wireless networking stops working
The internal wireless networking stops working on my 3050 after a few minures. If I connect an external USB wireless adapter it works.
  • 2 more comments
  • Anonymous Jun 17, 2008
    cannot connect to the router,the settings on the router are wpa psk, but i do not have that setting on my laptop?
  • basmoham Aug 13, 2008
    I would like to speak to a live Person Please
  • Anonymous May 11, 2010
    Go to Start -> Run -> type cmd then hit enter -> Type IPCONFIG. Let me know what it says.
    Does the wireless light on the laptop stay on, or does it shut off as well?
The wireless light stays on.
Posted on Feb 11, 2008
6ya staff
SOURCE:
Do I need a USB adapter to connect to a wireless network?
You need a wireless card. It could internal or external as a USB device.
May 20, 2013 | eMachines T5048 PC Desktop
My wireless printer hp deskjet 3050 is not printing the wireless blue light keeps blinking and does not go solid like it used to what do i do?
if the wireless blue light is blinking, it means it's not connected to the router or it's not communicating with it.If wireless blue light is solid ,it means it's connected to the network.
you will need to reconnect the printer to the network by using a USB cable.it will configure the wireless connection.
  1. to start the installation ,click on the start button on the computer
  2. click on programs or all programs depending on the operating system on the computer
  3. look for the HP folder and then left-click on it
  4. inside the HP folder,left-click on DESKJET 3050a or DESKJET 3050 series
  5. inside the DESKJET 3050 folder, left-click on product setup and software
  6. left-click on connect a new printer
  7. it will open up a page with options on how to connect the printer
  8. select wireless and then hit next
  9. if you are prompted to connect the usb ,please connect it
  10. if it asks you whether printer is connected to the network,select no
  11. click on next
  12. if usb is already plugged in,tick the box that says it's already plugged in
  13. hit next
  14. wait for the prompt to unplug the cable
  15. try printing wirelessly
let me know if these steps do not solve your problem.
Jul 15, 2011 | HP LaserJet 3050 All-In-One Printer
Does my hp pavillon s7310n slimline PC have wireless internet capabilities
Not built in, but you can pick up a USB adapter such as this one for cheap: moz-screenshot-1.pnghttp://www.walmart.com/ip/CNet-CQU-906-Wireless-N-PicoUSB-Dongle/15571889?sourceid=1500000000000003142050&ci_src=14110944&ci_sku=15571889moz-screenshot.png
Mar 01, 2011 | HP Pavilion s7310n (EN996AA) PC Desktop
I'm trying to connect my wireless HP DeskJet 3050 printer with my computer. In the set up it said to Press the WPS button on the router. The product automatically finds the wireless network and configures...
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
Feb 10, 2011 | Arris SURFboard SBG900 Wireless Router...
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
Cant connect wireless
If the stick is the solution, why are you avoiding the solution?
From what you have said, the internal wifi in the Evo doesn't work, while
an external usb stick does.
Assuming that your internal wifi is properly configured and functional, it is
incapable of picking up your home wifi signal, though it might be functional in other situations ... Buying an external usb stick gives you a better antenna position and takes nothing away from your system, while adding functionality and sheilding the innards of your system from viral
attack as a first line of attack that is detachable.
Buy the USB stick.
Bue
Apr 14, 2009 | Compaq Evo N600c Notebook
Compaq Presario F500 Laptop Internal Wireless Card
You should be able to use a usb wireless
just make sure it's compatible with your pc
What exactly is wrong with the internal one
did you repair person actually look at it
Jan 13, 2009 | Computers & Internet
I dont know how to connect wireless internet from one computer to another
You will need a wireless adapter for the other computer. You can get an external wireless USB adapter to connect to your wireless network. Simply plug it in and install the software. There will be a tutorial on the procedure which should include how to set encryption to keep nearby wireless networks from spying on you.
If you do not have an unused USB port, you can connect a USB hub to add additional ports or install an internal adapter instead. If your computer has an available slot, purchase a wireless internal network adapter, and then open the packaging and read the instructions. Insert the CD that comes with the adapter in your computer, and follow the manufacturer's instructions to install the necessary software.
Aug 24, 2008 | Computers & Internet
Wireless Lan not working
go to ur network connections, and Repair ur network adapter by rightclicking on it, and choose repair, hopefully this fixes ur problem
Feb 10, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3050-1733 Notebook Logo
178 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
