Question about Samsung DynaFlat TX-P2775H 27" TV
Wavy picture Picture always starts off fine when turn it on. Gets increacingly (20 min) wavy at the edges until it is almost the entire picture. Goes back to normal if i turn it off for a few minutes, but then begins to degrade again.
  • 281 Answers
You have problems with your power supply filters. I'd suggest you to change the mainfilter, that is the capacitor just after the ac rectifier and the b+ filter, that is the capacitor at the output of the smps, and then vertical filter and video filter. These are all capacitors with higher microfarad ratings, if you are not much comfortable, it's better to get some help from someone who is familiar with these. Pay attention not to reverse the polarity when changing the capacitors.
Posted on Jan 28, 2008
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
When turned on picture is very wavy (can't tell what you are even watching). After a time it becomes clearer until picture eventually returns. Recently, picture is wavy, mores on top, and has a slight...
The problem is from the lamp of the television, it seems to be having some faults, it is gradually getting damaged.
It will start by being wavy until it goes completely blank.
Some lamps go for about $125 or more. Some go for $200.
Take care and Good luck
Oct 23, 2010 | Televison & Video
2007 Sony KDL52XBR TV with blurred display for 20 min then fine
This is a known issue with the unit that you have. It is called an LCD tab bonding defect. If you want to try to repair it, you need to get the unit apart so that you can access the edge of the lcd panel. Power it on and observe the picture and then press the edges of the display and see if you can locate the point that the edge has the defect. If you can locate that point then you have 2 options, Uncovering that point as best that you can and using a heat gun to attempt to reflow the connections OR you can find something to clamp that point and hope that it holds, otherwise you are going to have to pay for a new screen. You cannot order it yourself because they wont ship to you.
Nov 19, 2017 | Sony KDL-52XBR4 LCD Monitor
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Wavy picture
It is capacitors in your TV set. If you fix it before the set goes out, you will save about a grand. Contact me @ techman32k@yahoo.com
Mar 24, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Samsung DynaFlat TX-P2775H 27" TV Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
