Re: My phone fell, now the lcd display is not working,...
You can try replacing lcd. Sometimes lcd breaks at the connectore point. this is not always visible. you can also get a free diagnosis and repair estimate from www.fixphonenow.com cell phone repair service.
In your case only with change your LCD is the answer to solve your problem.because the ink in the lcd was broke and formed like multiple colour line.I hope it help.
You should contact the manufacturer. The laptop is broken. Make sure you don't tell them it fell from a moving vehicle.. Probably not the best way to start or end that conversation. I'd go with... "It worked yesterday, but today the LCD wont display anything".. You're not lying. Either way if it's under warranty you're more likely to have it fixed. Otherwise, the LCD replacement is almost always more costly than simply replacing the laptop. Best of luck!
it means that your phones internal circuitry and programming is still working, but by the sounds of it, the screen or lcd display is broken sorry, take it to a mobile repair shop so they can actually have a look at it for you.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
You need a T-5 or 6 Torx Skrewdriver to do the job.
This is the solution! Please vote!
your unit experienced shock. due to fragility of the phone, your LCD might be broken, if not, the LCD connector needs to be refitted to its slot. If the problem is still the same, you need to replace ur LCD.
